Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 1,8 Pöörded
Pealkiri: A4 1,8 Pöörded (Vastuseid: 12 | Vaatamisi: 1763)
Reimo
Registreerunud 18.09.04
Auto: Peugeot 508SW, A4 B5
postitati 17.09.05 15:44 Tsiteeri
A4 1,8 Pöörded
Kas keegi oskab öelda palju peaks olema 1,8 tühikäigu pöörded?Mul nad praegu 900.Kas on see norm.või peaks nad olema madalamad?
karla
Registreerunud 18.03.04
postitati 17.09.05 19:06 Tsiteeri
see on normaalne;)
OOOO
Reimo
postitati 17.09.05 19:55 Tsiteeri
Juhtusin täna rääkima ühe autoelektrikuga ja ta arvas,et vist on nagu natuke palju.Ma ei oska seisukohta võtta.
TiitR2
Registreerunud 21.07.04
postitati 17.09.05 19:58 Tsiteeri
Algselt postitas: Reimo
aga kuula ka teise elektriku arvamust....oma TDI-l ntx. ca. 850 rpm.
Reimo
postitati 17.09.05 20:02 Tsiteeri
ahh,ega suurt vahet pole,ma rahul,aga mul venna A4 pöörded kõiguvad julmalt sellepärast ma mõtlesin,et minu omalgi ehk midagi korrast ära.
karla
postitati 17.09.05 20:10 Tsiteeri
Pigem on temal siis midagi korrast ära...
OOOO
Reimo
postitati 17.09.05 20:22 Tsiteeri
No tema autoga on hull gase.Umbes 3 nädalat tagasi saabus auto Saksamaalt.Registreerisime auto argis ära ja saime sõita Kannu bubi taha ülevaatus punkti juurde.Seal auto enam ei käivitunud.Kus juures bensupump tegi seal imelikku häält.Vedasime siis ta Mustamäe teele pumba remontti,seal väideti,et pump korras ja mingi elektri kamm on.Järg siis elektrikku juurde.Elektrik siis ke..is oma ajusi paar päeva ja ei saanud sotti mis viga.Arvas,et orig immo paneb põide.Tee viis siis Reval autosse ja seal tuli välja,et bensu paak on jummala sodi,kusjuures ülevaltpoolt.Täna sai vahetatud paak koos pumbaga ja saime auto lõpuks käima aga pöörded kõiguvad nii,et kui lased pöörded 6000 peale ja lased gaasi lahti siis tahab välja surra aga ei sure vaid kõigub ja natukese aja pärast tõmbab pöörded normaalseks.
Krt tuli vist segane jutt aga loodan,et saite aru :)
Vaarao
Registreerunud 04.04.05
Auto: A4 95 a.
postitati 17.09.05 20:36 Tsiteeri
Ma käisn mõni aeg tagasi õli vahetust nullimas ja siis kontrollisime veel mõningaid näite.Pöörded kõikusid kuskil 870-880 juures.Temp.93 kraadi.Pidi olema norm.
postitati 18.09.05 08:52 Tsiteeri
Autodata järgi 820-900 Not adjustable. Seega regullida seal niikuinii midagi pole.
piltnik
Registreerunud 26.04.05
Auto: A4 1.8TQ
postitati 18.09.05 15:02 Tsiteeri
minu omal 850-900 usun et nii peab olemagi
postitati 18.09.05 16:49 Tsiteeri
Algselt postitas: piltnik
Sul on tegelikult turbokas juba, mitte tavaline 1.8.
piltnik
Auto: A4 1.8TQ
postitati 20.09.05 13:26 Tsiteeri
Algselt postitas: Black
kas turbokal ja mitte turbokal on erinevad tühikäigu pöörded?
Rainis
Registreerunud 08.01.05
Auto: Lancer
postitati 30.09.05 16:31 Tsiteeri
Täpsemalt jama siis selline, et paak vahetati ära.
Sellel paagi vahetusel ei pruugi muidugi mingit seost pöörete kõikumisega olla kuid siin siis veel lisa infot.
Kui paagis on bensiini umbes 10-15 liitrit ehk mingi aeg enne bensutule süttimist töötab auto laitmatult(pöörded u.800-900 vahel ja ei kõigu). Nüüd lasin siis bensiini sisse 30L ja jama jälle käes. Tagant suitseb ka kuidagi kahtlaselt palju.
Igasugune info on siis teretulnud enne 05.10.2005.
Tänud!
Asi korras! Diagnostika näitas siis, et bensiinipaagi tuulutusklapp vaja ära vahetada.
[PHP: 49.5% - SQL: 50.5%]
