Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - jahutus ei toimi (korras)
Pealkiri: jahutus ei toimi (korras) (Vastuseid: 19 | Vaatamisi: 1713)
kaurs
Registreerunud 26.03.05
Auto: A6 C7 3,0tdi quattro
postitati 11.09.05 19:42 Tsiteeri
95.a A4 Asi läheb koguaeg keema,termostaat sai vahetatud ja plokikaanega ja tihendiga on ka kõik korras, asja teeb imelikuks see et ylemine lõdvik tuline ja alumine ainult õrnalt leige???? milles asi?:o
Speiss
Registreerunud 18.10.04
Auto: Ford :(
postitati 11.09.05 19:52 Tsiteeri
kui alumine leige ja keema läheb, siis ainult üks võimalus - pidevalt väikse ringi peal
põhjuseks enamasti vigane termostaat aga võib olla ka mingi ummistus vms kuskil.
kaurs
postitati 11.09.05 19:53 Tsiteeri
termostaat sai just vahetatud aga jah kõige tõenäolisem paistab vist ummistus ikka jah
Timo
Registreerunud 25.08.04
postitati 12.09.05 13:31 Tsiteeri
Ettevaatlik peab olema selle keema laskmisega. Sõit tuleks lõpetada ikka enne keema laskmist:o
Rain
Registreerunud 05.10.03
Auto: Allroad ja A6 Allroad
postitati 12.09.05 14:28 Tsiteeri
Pigem vastupidi kui hakkab keema minema (näiteks: ummikus) siis kuskilt siva mingi sirgem ots ja talda anda niikaua kuni temp alla läheb. Mittemingil juhul ei ole hea mootorit väljasuretada.
kaurs
sad.gif postitati 12.09.05 14:51 Tsiteeri
ei sõitma ma seda masinat enne ei vii kui asi korras, aga minu mõistus on otsas ja viga ikka veel leidmata.
Rain
postitati 12.09.05 15:02 Tsiteeri
Algselt postitas: kaurs
Veepumpa võiks ka kontrollida.
rempsel
Bännitud
Registreerunud 13.09.05
Auto: Audi Q7 3.0 S-Line 2007
postitati 14.09.05 03:52 Tsiteeri
kuda seda veepumpa kontrollida????
RICHARD
Registreerunud 16.11.04
Auto: Audi A4 1.8
postitati 14.09.05 04:08 Tsiteeri
Paisupaagi korki võiks vaadata. Väga levinud viga. Vaheta ära, ei maksa palju.
art
Registreerunud 29.01.05
Auto: A4 Avant 1.9TDI oli 80 1.8S,Honda CBR1100XX Bläku.
postitati 14.09.05 15:04 Tsiteeri
Temp mahavõtmiseks piisab salongi kütte sisse lükkata.
kaurs
postitati 14.09.05 19:16 Tsiteeri
ega siin jah muud yle ei jää kui tuleb,katsetama hakkata! kuid jah remondimehed arvasid enamus ikka et pump õhtal
kaurs
sad.gif postitati 24.09.05 10:58 Tsiteeri
nyyd siis kõik võimalik vahetatud. termostaat korras,pump vahetatud,paisupaagi kork vahetatud. Aga asi ikka ei toimi,ikka krt läheb keema:(
V200
Registreerunud 11.09.04
postitati 24.09.05 11:40 Tsiteeri
Kas salongi sooja tuleb? Kui salongiradikas soojaks läheb, siis on ilmselt ikka ummistus mootori radika juures.
Katsu ka survet lõdvikutes.
kaurs
postitati 26.09.05 18:43 Tsiteeri
salongi sooja tuleb,ja eest radikas on kõikjalt yhtlaselt soe,jama aga selles,et ylemine lõdvik on tulikuum ja alumine täiesti kylm,nagu termostaat ei töötax aga ometi on ta korras.:o
jan-kos
Registreerunud 23.04.03
postitati 27.09.05 06:22 Tsiteeri
Prooviks viska termostaat üldse vahelt ära,võid lõdvikud ka läbi puhuda,aga nii suur ummistus on kahtlane ja termostaadi avanemine proovi kuumas vees järgi.Või on radikas seest nii umbes? :o
kaurs
postitati 27.09.05 10:16 Tsiteeri
ilma termostaadita asi toimib ideaalselt,termostaat on kah juba potis ära käinud ja töötab. asi muutub järjest segasemax:(
V200
postitati 27.09.05 10:33 Tsiteeri
Kui ilma termostaadita jahutus toimib, siis on kõige lihtsam samm ikka mõnda teist termostaati proovida. Mis sest, et potis vana termostaat töötas.
Muidugi on ka võimalus, et termostaadile ei voola kuum jahutusvedelik peale ja seepärast ei saa termostaat aru, et tuleb avaneda. ;)
Mis mootoriga tegu üldse?
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 28.09.05 09:01 Tsiteeri
Peale termostaadi vahetust tuleks radika ülemine lõdvik lahti võtta ja sealtkaudu kõigepealt mootoriplokk täis valada,siis lõdvik radika külge tagasi ja alles peale seda paisupaak täita.
Nüüd kork korralikult peale ja proovima.
Kui plokki täis ei vala siis tihti ei saa termostaat kuskilt avanemiseks piisavalt temperatuuri,kuna suur osa mootoriplokist on sõna otseses mõttes kuiv.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 29.09.05 11:41 Tsiteeri
üks võimalus on, et "väike ring" on umbes - st kinnise termostaadi korral jahutusvedelik termostaadi ümber üldse ei ringlegi.
kaurs
postitati 29.09.05 11:46 Tsiteeri
niih,nyyd sai siis veel yks termostaat järgi proovitud,ja asi hakkas toimima,ja veel oli oma lepingu ka jahutustiiviku sidur ära lõpetanud. loodan et nyyd asi jääb pidama. Tänud kõigile abilistele :)
[PHP: 48.3% - SQL: 51.7%]
