Pealkiri: A6 3.0tdi 165kw 2005 glow plug light vilgub (Vastuseid: 7 | Vaatamisi: 2905)
mernis
Registreerunud 28.07.18
Auto: Audi A4 B5 1.8T 110kw , A6 C6 3.0TDI 165kw QUATTRO
postitati 16.07.20 10:51 Tsiteeri
Tere, autoks audi A6 3.0tdi 165kw 2005 ja vahepeal hakkab vilkuma glow plug light. Milline viga võib seda põhjustada? Panen ka diagnostika siia alla.
Tuesday,14,July,2020,15:10:25:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ4F86N105815 License Plate:
Mileage: 346240km-215143mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 57 61 62 72 76 77
VIN: WAUZZZ4F86N105815 Mileage: 346240km-215143miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F0 910 402 L HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0010
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 02335 785 00200
VCID: 2643409991E70A7A8F-8072
5 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 344817 km
Time Indication: 0
Date: 2020.06.26
Time: 22:10:19
Freeze Frame:
RPM: 756 /min
Torque: 54.6 Nm
Speed: 0.0 km/h
Voltage: 13.45 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 005 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 0
Fault Frequency: 103
Reset counter: 255
Mileage: 344817 km
Time Indication: 0
Date: 2020.06.26
Time: 22:11:19
Freeze Frame:
RPM: 126 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Temperature: 84.6C
Duty Cycle: 80.9 %
Voltage: 10.18 V
Duty Cycle: 88.8 %
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 26
Reset counter: 255
Mileage: 344972 km
Time Indication: 0
Date: 2020.06.28
Time: 13:32:23
Freeze Frame:
RPM: 1638 /min
Torque: 113.1 Nm
Speed: 50.4 km/h
Duty Cycle: 78.7 %
Duty Cycle: 20.9 %
Mass Air / Rev.: 446.5 mg/str
Duty Cycle: 46.6 %
000565 - Boost Pressure
P0235 - 001 - Regulation Range not Reached - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 345052 km
Time Indication: 0
Date: 2020.07.01
Time: 09:39:16
Freeze Frame:
RPM: 2142 /min
Torque: 304.2 Nm
Speed: 54.9 km/h
Absolute Pres.: 1805.4 mbar
Absolute Pres.: 1060.8 mbar
Mass Air / Rev.: 505.3 mg/str
Temperature: 19.8C
005445 - Throttle Valve Controller
P1545 - 002 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 346182 km
Time Indication: 0
Date: 2020.07.13
Time: 19:15:18
Freeze Frame:
RPM: 756 /min
Torque: 46.8 Nm
Speed: 0.0 km/h
Voltage: 13.68 V
Duty Cycle: 24.1 %
Bin. Bits: 000
Mass Air / Rev.: 475.9 mg/str
Readiness: 0 3 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0050
Revision: --H01--- Serial number: 4104154
Coding: 0000001
Shop #: WSC 88888 121 80534
VCID: 2345598DE2D5FF52E8-8076
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
Shop #: WSC 00011 000 00000
VCID: 2D51BFB5B41139224E-8078
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600700284810
Coding: 0000131
Shop #: WSC 00939 264 89439
VCID: 63C5198DA255BF52A8-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 351JQ057513095
Coding: 0001001
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000268038
Subsystem 3 - Serial number: 0102.11.050000000100010457
Subsystem 4 - Serial number: 010457
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030069810
Coding: 0000278
VCID: 5BB5216D9A258792E0-800E
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 344394 km
Time Indication: 0
Date: 2020.06.18
Time: 16:59:59
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0002121
VCID: 2A5BB4A985FF2E1AAB-807E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
02747 - Solenoid for Bi-Xenon Shutter; Right
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 262136 km
Time Indication: 0
Date: 2020.06.28
Time: 00:38:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8009060
Shop #: WSC 00000 000 00000
VCID: 1C376271DFABC0AA29-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD0AT2FE
Coding: 0013362
Shop #: WSC 02325 785 00200
VCID: 29594BA580F92502A2-807C
Subsystem 1 - Serial number: 6332CSME0C495A102
Subsystem 2 - Serial number: 6342CSME0C57263C9
Subsystem 3 - Serial number: 6352QSME06780C7BS
Subsystem 4 - Serial number: 6362QSME060C4717F
Subsystem 5 - Serial number: 63734SME060C4167.
Subsystem 6 - Serial number: 63834SME042B3E03$
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks䵬enmodul H07 0230
Revision: 00H07000 Serial number: 90026052960302
Coding: 0002142
VCID: 66C300995167CA7A4F-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 F
Component: KOMBIINSTR. M73 H16 0630
Revision: 00200000 Serial number: 4PV30X4C5
Coding: 2049043
Shop #: WSC 80093 222 69422
VCID: 21495385F8C9ED42FA-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805B01805D
Coding: ECFE73C41B3504
VCID: 275D4D9D96ED1372B4-8072
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H46 0850
Revision: 00000000 Serial number: 364KV057503465
VCID: 3B7581ED7A65A792C0-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 F HW: 4F0 959 793 F
Component: TSG FA H21 0050
Coding: 0001546
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01008422970000
Coding: 0393861
VCID: 2E53B8B9B917423A77-807A
3 Faults Found:
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 80
Mileage: 338018 km
Time Indication: 0
Date: 2020.03.04
Time: 17:40:22
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 44
Reset counter: 105
Mileage: 344368 km
Time Indication: 0
Date: 2020.06.15
Time: 16:25:47
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 110
Mileage: 342598 km
Time Indication: 0
Date: 2020.05.20
Time: 21:27:08
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 31S00001 Serial number: 00111050171830
Coding: 0000102
VCID: 224B5C89FDCFF65AE3-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000154096
Coding: 0001013
VCID: 5EB32879893792BA87-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 F HW: 4F0 959 792 F
Component: TSG BF H21 0050
Coding: 0001546
VCID: 2C57B2B18F0B302A59-8078
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 344394 km
Time Indication: 0
Date: 2020.06.18
Time: 16:59:54
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: 5DB12F75843189A29E-8008
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Coding: 0000003
VCID: 3A7B84E9755F9E9ADB-806E
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352K.057594239
Coding: 0000001
VCID: 3169A3C5A8295DC26A-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H05000 Serial number: 76300700028001
Coding: 0000301
VCID: 25414795ECE1016286-8070
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000147726
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1234567890
Coding: 344630393135313035442056413031323334353637383930
Shop #: WSC 36570 002 1048576
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0050
Coding: 0001026
VCID: 2F6DA5BDBE1D4B327C-807A
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0050
Coding: 0001026
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 11820529201938
Coding: 0201016
VCID: 24475A91E7DBF86A91-8070
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 79
Mileage: 344394 km
Time Indication: 0
Date: 2020.06.18
Time: 17:38:05
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007591205
Coding: 0010900
End-------------------------(Elapsed Time: 02:28)--------------------------
Rain573
Registreerunud 17.09.05
postitati 16.07.20 11:01 Tsiteeri
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 344817 km
Time Indication: 0
Date: 2020.06.26
Time: 22:11:19
VAG Online kodeerimine, component protection, immo, SVM, diagnostika, elektritööd, lisaseadmete paigaldus, dpf-egr- dtc jne delete, chip. Kliima kontroll, täitmine, remont...
postitati 16.07.20 11:25 Tsiteeri
Algselt postitas: mernis
Kus? Näen ainult autoscani veakoodide rodu. Kui tehti diagnostika, siis peaks viga juba teada olema ju.
mernis
postitati 16.07.20 13:28 Tsiteeri
Vno jah autoscan sai ise tehtud
postitati 16.07.20 14:50 Tsiteeri
No aga vahva ju, nüüd jääb ainult välja mõelda, mis viga on ja ära parandada. Hoidsid kokku aga teada ei saanud suurt midagi.
Vihje;
mernis
postitati 16.07.20 17:15 Tsiteeri
Kas oleks kedagi Harjumaa piires kes saaks üle vaadata ja täpselt öelda mis viga mingi mõistliku hinna eest ja palju parandus läheks? Või on parem minna esindusse?
postitati 16.07.20 18:26 Tsiteeri
Kusjuures throttle ja mootor korraga, ehk siis võib ainult üks neist vigane/lühises olla ja teine niisama järgi...
ivorturb12
Registreerunud 21.10.08
postitati 01.02.21 19:46 Tsiteeri
Kasutan kellegi vana teemat
Sama auto nagu teemas, c6 3,0 165kw
Algne probleem oli see, et viskas eelsüüteküünlatule vilkuma kiirendades ja oli avariis. Veakoodi järgi turbo juhtmooduli rike sees. Kuna autol oli mitu teist viga ka juures ning nina tuli eemale tõmmata, sai algul teiste asjadega tegeletud. Kui ülejäänud asjad korda said, sai süsteem ära survestatud ja cooleri juurest üks lõdvik susistas läbi. Sai see viga kõrvaldatud ning auto kokku ja proovima. Avariisse ei visanud enam, kuid kuni ca 2500 pöördeni on täiesti uimane ning turbot pole absoluutselt järgi. Alates 2500 pöördest kuni lõpuni välja, liigub nii nagu peab ning ühtegi rikkekoodi järgi ei jäta. Arvutiga rõhku logides, 2500 pöördest edasi puhub isegi kerget ülerõhku, kuid mitte niipalju, et avariisse lööks, kuid alla selle on selline tunne, nagu oleks juhtmoodulilt pistik tagant võetud.
Arvutiga aktuaatorit testides liigub see ühest äärmusest teise ja tagasi nii nagu peab. Kui keerata süüde sisse, siis lükkab geomeetria varda ilusti teise äärde välja. Aga kui panna auto kohapeal käima, siis jääb aktuaator umbes poole peale seisma, kuigi peaks olema niiöelda teises punktis. Kuna arvutiga aktuaatorit liigutades liigub see sellises ulatuses, nagu peab ning süüte sisse pannes liigub ka sinna asendisse, kuhu peab, siis ei saa reaalselt mingit mehaanilist takistust olla nagu.
[PHP: 10.1% - SQL: 89.9%]
