Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kuidas saada pooltelje otsa pooltelje küljest kätte
Pealkiri: Kuidas saada pooltelje otsa pooltelje küljest kätte (Vastuseid: 9 | Vaatamisi: 2480)
juzzpoig
Registreerunud 09.08.05
Auto: 4motion passat
postitati 09.08.05 17:55 Tsiteeri
Justnimelt kysimus ongi selles, et kuidas saada pooltelje otsa pooltelje küljest kätte. Nimelt asi selles, et poolteljeotsa kaitsekumm oli katki läinud ja mõtlesin, et vahetan ise ära. Asi nüüd nii kaugel, et vaja ainult poolteljeots pooltelje kyljest lahti saada, aga ei taha sealt nuutidest mitte välja tulla. Kas on misge hea nipp äkki kuidas lihcalt kätte saada?
Taavi
Registreerunud 21.11.04
Auto: UrS4
postitati 09.08.05 17:58 Tsiteeri
Vaata kas on splint seal määrde sees. Kui pole tuleb tõmmates.
12.301@181km/h
juzzpoig
postitati 09.08.05 18:40 Tsiteeri
Selge üritan selle splindi üles leida ja eemaldada.
tänud
margus0000
Registreerunud 20.02.04
Auto: audi a3
postitati 09.08.05 19:42 Tsiteeri
ei ole vaja splinti eemaldada , selle sama poldi´millega pooltelg on rummu küljes kinni keerad lahti võtad pooltelje rummu seest välja ja keerad selle poldi uuesti sisse ja keerad nii kaua kuni pooltelg tuleb ilusti otsast ära , :D
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 09.08.05 19:43 Tsiteeri
Mis autoga tegu?
Kui liigendi välimisse otsa käib polt (näiteks 80/90/S2), siis käib välimine ots maha sedamoodi, et peale välimise otsa rattarummust väljasaamist tuleb seesama otsapolt tagasi otsa keerata. Selle lõpuni sisse keeramisel saabki liigend võlli otsast maha pressitud (ennem sigariga tegelnuna jäi alguses ka juhmilt vahtima, kui stopper määrde seest ei leidunud :D ).
Stopper ise on võlli nuutide peal olevas soones ja see tuleb peale lahtivõtmist kindlasti uue vastu vahetada (kaitsekummiga tuleb komplektis kaasa uus stopperrõngas ja distantsseib).
Nendel autodel, millel välimises otsas on mutter (100/200), saab aga selle stopperi sealt võllipoolsest otsast lahti ja selle järel libiseb liigend võlli otsast juba lihtsalt maha.
postitati 09.08.05 21:29 Tsiteeri
Nii 10a tagasi olen 100 '86 pooltelje otsa vahetanud. Polnud sellel kuskil otsas ühtki polti ja pooltelje nuutide keskel oli ikkagi ka stopperrõngas. Kuna sel ajal eriti kuskilt foorumist midagi küsida polnud, siis sai see ots sealt lihtsalt kuvalda ja torniga seestpoolt lüües maha taotud. :) Teine mees hoidis veovõlli kinni, et sisemine ots kastist välja ei liiguks. Mööda vart libiseva raskusega tõmmits oleks ilmselt intelligentsem vahend olnud, aga polnud seda ka käepärast.
genekas
postitati 10.08.05 00:51 Tsiteeri
No kui 200 '85 peal seda asja tegi, oli Haynesi raamat abiks kõrval ja sealt sai järgigi vaadatud.
Tollest on ka miski 5 aastat vist, aga kui õigesti mäletan, siis sai selle stopperrõnga seal ilusti "laiali tõmmata" ja see jäi liigendi küljes olevasse soonde - mingit kuvaldat kasutada küll ei tulnud ei lahtivõtmisel ega kokkupanekul.
Aeg on oma töö teinud ja võibolla ei ole kõik enam õigesti meeles, aga see on kindel, et praeguse auto konstruktsioon ja antud töö teostamise viis on tollega võrreldes teistsugused just sellesama otsa lahtivõtmise ja kokkupaneku osas.
Siin on raudselt inimesi, kes on mõlemat sorti autodega rohkem tegelenud ja nemad võivad täpsustada, kui midagi valesti meelde on jäänud
juzzpoig
postitati 10.08.05 05:25 Tsiteeri
Autoks on audi 100 2,5 TDI aastast 90, ehk siis üks viimastest sigaritest.
Seega peaks asi nii käima, et võtan poolteljeotsa sealt rummu seest välja ja keeran poldi sisse ja peakski nagu kenasti otsast ära tulema?
janar
Registreerunud 16.11.03
Auto: A6 Avant
postitati 10.08.05 05:28 Tsiteeri
kui sul on poldiga variant, siis just nii see tuleb jah!
juzzpoig
postitati 10.08.05 05:36 Tsiteeri
Algselt postitas: audifan
Jah, polt sealt ratta otsast välja tuli
[PHP: 50.5% - SQL: 49.5%]
