Pealkiri: Audi A6 C7 adaptiivne püsikiirus (Vastuseid: 4 | Vaatamisi: 2967)
Tarvin
Registreerunud 14.10.10
Auto: Audi A6 C7 2013 S-line
postitati 22.06.19 12:10 Tsiteeri
Mure selline, et viimasel ajal ei tööta enam adaptiivne püsikiirusehoidja. Viskab armatuurile, et ACC and audi braking guard not available. Viga sai alguse sellelst talvest, kui viga tuli ainult vahepeal esile ning siis kadus ära. Nüüd aga viimased nädalad on viga püsiv ning enam ei saa üldse püsikiirust kasutada. Lisan siia veakoodid, mida ei saa ära kustutada ning mis tulevad koguaeg tagasi:
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7F04010202
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 285988E25384715EF3D-807D
1 Fault Found:
145408 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 167
Mileage: 208155 km
Date: 2019.06.22
Time: 12:40:38
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 H
Component: H-BNT-EU H50 1034
Revision: -------- Serial number: 190B.0D7531659
Coding: 050100010303F9FF7FB0EF3E00000003080001000000000000
VCID: 316F6586685E3096243-8064
Subsystem 1 - Part No: 8R0 060 884 EM
Component: EUR 2017/2018 2503
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
2 Faults Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 208155 km
Time Indication: 0
Date: 2019.06.22
Time: 12:41:49
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000010
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 208155 km
Time Indication: 0
Date: 2019.06.22
Time: 12:41:49
Freeze Frame:
Voltage: 14.10 V
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 264586DA5990672EC11-8073
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 167
Mileage: 208155 km
Date: 2019.06.22
Time: 12:42:13
Rain573
Registreerunud 17.09.05
postitati 22.06.19 12:29 Tsiteeri
Võiks tähelepanu pöörata GPS antennile.!
Tarvin
postitati 22.06.19 14:08 Tsiteeri
Võtsin katusel oleva antenni maha. Sinna jookseb sisse gpsi ja telefoni valguskaabel. Kui telefoni kaabel lahti ühendada, siis tekib koheselt ka vastav veakood. Gpsi kaablit lahti või külge ühendades jääb alati viga samaks. Kas tõesti ACC on ühenduses gps antenniga? Ja kas ebay kõige mõistlikum lahendus uue antenni jaoks?
wtf_
Registreerunud 28.05.05
Auto: RS6 C7
postitati 22.06.19 15:56 Tsiteeri
Jah, gps antenn ja ACC on omavahel seotud. Mu meelest ebays uusi polnud väga odavalt ja tahtsin kiirelt, seega ostsin ise esindusest (128€).
Rohkem saad lugeda ka mu auto teemast (just vahetasin enda masinal seda):
https://foorum.audiclub.ee/viewthread.php?tid=181163&page=3
Tarvin
postitati 22.06.19 19:21 Tsiteeri
Aitäh vastuse eest. Ilmselt samuti kiireim viis minna esindusse ja osta sealt see.
[PHP: 12.1% - SQL: 87.9%]
