Pealkiri: A6 c6 3,0 veakoodid. (Vastuseid: 4 | Vaatamisi: 2179)
miilits22
Registreerunud 17.12.10
Auto: g4,b5.5,e91xd,b7/4motion,e61, c6allroad, b8 bitdi 4mo, c6q, A8d3q 261kw
postitati 11.05.19 12:45 Tsiteeri
Tere, küsiks targematelt mõne veakoodi kohta seletust, mis on mälus kahel huvipakkuval masinal. Kui keegi oskab pakkuda, siis huvitaks ka miski eelarve nende suhtes :) :)
Esimesel küünlad vahetada ja ilmselt aku kustunud, kuna ajutised vead tunduvad, aga mis see solenoid viga kujutab.
Address 01: Engine Labels: 059-907-401-BPP.clb
Part No SW: 4F5 910 401 M HW: 4F0 907 401 C
Component: 2.7L V6TDI G000AG 0020
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 02335 785 00200
VCID: 2B55B1AE8A05361C9D-807E
2 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.17
Time: 13:45:03
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 11.17 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
001650 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.26
Time: 16:58:26
Freeze Frame:
RPM: 924 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.68 V
Duty Cycle: 24.1 %
Temperature: 10.8°
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01091593410000
Coding: 0139909
VCID: 3169A3C6A8295CCCA7-8064
1 Fault Found:
01699 - Motor for Central Locking; Hatch/Trunk (V53)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Mileage: 218302 km
Time Indication: 0
Date: 2019.05.04
Time: 14:20:01
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000000802
Shop #: WSC 37605 141 03657
VCID: 24475A92E7DBF9645C-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2801180920
Coding: 344630393135313035442056413032383031313830393230
Shop #: WSC 12345 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.17
Time: 13:47:27
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.17
Time: 14:48:30
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.17
Time: 14:53:18
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.17
Time: 14:53:28
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 218301 km
Time Indication: 0
Date: 2019.04.17
Time: 14:53:38
Masin 2 samuti küünlad, aga tagaluugi viga? Seal avamisel kui tõmmata, siis mootor nagu korduvalt klõpsis, tõk-tõk-tõk seda siis kui nagu aeglaselt avada. Kui vajutada ja kiirelt luuk lahti tõmmata ei tekkinud seda häält. Mingi lühis, juhteme viga`? Mis viga air mass sensoriga.
4 Faults Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 197546 km
Time Indication: 0
Date: 2018.06.15
Time: 06:56:01
Freeze Frame:
RPM: 882 /min
Torque: 89.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.38 V
Duty Cycle: 24.9 %
Temperature: 31.5°C
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 197546 km
Time Indication: 0
Date: 2018.06.15
Time: 06:56:01
Freeze Frame:
RPM: 882 /min
Torque: 89.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.38 V
Duty Cycle: 24.9 %
Temperature: 31.5°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 197546 km
Time Indication: 0
Date: 2018.06.15
Time: 06:56:01
Freeze Frame:
RPM: 882 /min
Torque: 89.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.38 V
Duty Cycle: 24.9 %
Temperature: 31.5°C
000260 - Mass Air Flow Sensor (G70)
P0104 - 001 - Intermittent - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 167
Reset counter: 48
Mileage: 198046 km
Time Indication: 0
Date: 2018.06.18
Time: 09:31:55
TiitR2
Registreerunud 21.07.04
postitati 11.05.19 13:01 Tsiteeri
Luugil ilmselt mootori mikrolüliti otsi andmas, suht tavaline, enda omal äsja vahetasin.
miilits22
postitati 11.05.19 13:40 Tsiteeri
Algselt postitas: TiitR2
Luugil ilmselt mootori mikrolüliti otsi andmas, süht tavaline, enda omal äsja vahetasin.
Mis uus maksab?
TiitR2
postitati 11.05.19 13:59 Tsiteeri
Algselt postitas: miilits22
Mis uus maksab?
Q7-le maksis OE mingi 55.- kandis.
Edit: Nii Peetri, kui Mooni Forssis kohapeal olemas su autole ja nõks üle 50.- maksab.
Peaks olema koodiga: 8P4827505D
Oja1
postitati 11.05.19 23:11 Tsiteeri
... aga mis see solenoid viga kujutab.
Address 01: Engine
Mootoripadi (kinnitus).
[PHP: 14.5% - SQL: 85.5%]
