Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: Audi Coupe (kuubiku) velgede poldivahe?
Pealkiri: K: Audi Coupe (kuubiku) velgede poldivahe? (Vastuseid: 11 | Vaatamisi: 1895)
wtf_
Registreerunud 28.05.05
Auto: RS6 C7
postitati 30.07.05 14:58 Tsiteeri
Auto siis Audi Coupe 1983.a.
Väga vabandan selle lolli teema ees, mis tegin, aga mul nagu täiesti arusaamatu. Nimelt vaatasin velgede sobivustabelist, et poldivahe on 4x108, aga siis mõõtsin ise ja tundub, et on 4x100.
Oleks tänulik kui keegi ütleks, mis siis poldivahe on? Keskava peaks olema 57mm onju?
Tänud!
janar
Registreerunud 16.11.03
Auto: A6 Avant
postitati 30.07.05 15:31 Tsiteeri
4x100 jah
wtf_
Auto: RS6 C7
postitati 30.07.05 15:41 Tsiteeri
Suured tänud! Asi siis lahendatud ja nüüd saan velgi endale otsida.
janar
Auto: A6 Avant
postitati 30.07.05 16:21 Tsiteeri
mis velgi otsid..mul on pakkuda 13" valusid
MTI
Registreerunud 16.07.05
Auto: '84 Audi 100 Avant 2.3 NG
postitati 30.07.05 17:33 Tsiteeri
oh sa raisk, mul vist ka 4x100 vist siis, alati arvasin et 4x108, hea et velgi juba kuskilt ostnud pole
Vidiit
Registreerunud 23.11.03
Auto: Audi 80 Coupe GT
postitati 31.07.05 01:01 Tsiteeri
kõik pole 4x100, on ka 4x108 variante
MTI
postitati 31.07.05 12:44 Tsiteeri
vabandan segaduse pärast, mul ikkagi 4x108
K1KaZ
Registreerunud 24.11.04
Auto: Kolm kuubikut :)
postitati 31.07.05 17:42 Tsiteeri
V:
Orginaalis kindlasti alla 85a Coupe'del 4x100 auguvahe uuematel kasutati juba 4x108 kuna mootorid muutusid võimsamateks & ka piduritega tuli midagi ette võtta, siis tehti suuremad kettad & ju siis liikus ka auguvahe.
Oleneb siis nii aastarvust kui mootorivõimusest aga kuna kõik jupid on vahetatavad siis EI tea keegi mis autoga kunagi tehtud on.
Ma kah ainult oletan ega pa päris kindel pole :P
Quattro'ga lumepeal käia on hea :D
WhiteLion
Registreerunud 22.02.04
Auto: Poolik Coupe GT
postitati 31.07.05 21:02 Tsiteeri
Algselt postitas: K1KaZ
Orginaalis kindlasti alla 85a Coupe'del 4x100 auguvahe uuematel kasutati juba 4x100 kuna mootorid muutusid võimsamateks & ka piduritega tuli midagi ette võtta, siis tehti suuremad kettad & ju siis liikus ka auguvahe.
Parandused: tagumine 4x100 peaks olema 4x108 ehk 85.a ja edasi tulid 4x108 auguvahega.
madjs
Registreerunud 28.10.02
Auto: Audi 80 b4 1,9tdi, Suzuki VX 800, Golf 2 GTI, Megan Coupe 108kw
postitati 01.08.05 08:46 Tsiteeri
Algselt postitas: WhiteLion
Minul 87 aasta cuubik ja 4x100, ühesõnaga enne kui velgi ostma, siis vaja ikka üle mõõta millega tegu:P
mulds
Registreerunud 29.01.03
Auto: Audita
postitati 01.08.05 10:00 Tsiteeri
kui ei eksi siis need, millel taga ketas siis 4x108
millel trummel siis 4x100
btw minu 84a kuubikul on 4x108
Vidiit
postitati 02.08.05 00:14 Tsiteeri
see on tõesti nii, etkui on kettad taga, on ka 4x108. uuematel samuti 4x108, kuid vaid võimsamate mootoritega. kuna mul oli stockis 1.8 moto, oli taga trummel, hoolimata 1987.a. väljalaskest.
[PHP: 52.4% - SQL: 47.6%]
