Pealkiri: Audi a4 b8 veakoodid. (Vastuseid: 8 | Vaatamisi: 2578)
Meissel2
Registreerunud 19.12.16
Auto: Audi A4 3.0 Quattro TDI 176kW
postitati 31.03.19 12:12 Tsiteeri
Tervist,
Juhtus nimelt selline asi, et hakkasin läbi auto bluetoothi helistama ja samal ajal sõitma ning viskas korraga hunniku vigu ette. Ma pole väga "sina" peal nende asjadega ning mõtlesin, ehk oskab keegi siin abi/nõu anda. Ise arvaksin, et hunnik elektrilisi vigu lendas välja, kuna samal ajal tekkisid.
Address 01: Engine (J623-CAPA) Labels: 059-907-401-V1.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0004
Revision: --H01---
Coding: 0104002C180F0118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02004
ROD: EV_ECM30LTDIA5.rod
VCID: 2E5496977104E24EFF-807A
3 Faults Found:
4698 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 261337 km
Date: 2019.03.30
Time: 17:36:08
5308 - Throttle Body Actuator Bank 1 (J338)
P0638 00 [175] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Mileage: 261337 km
Date: 2019.03.30
Time: 17:36:47
5061 - Supply Voltage B for Injectors
P1042 00 [032] - Circuit Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 261337 km
Date: 2019.03.30
Time: 17:36:07
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 S HW: 8K0 907 379 S
Component: ESP8 quattro H04 0210
Revision: -------- Serial number: --------------
Coding: 1B0D00
VCID: 499EC50BE0AAA576CA-801C
3 Faults Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 230
Mileage: 260954 km
Time Indication: 0
Date: 2019.03.25
Time: 15:50:21
Freeze Frame:
Hex Value: 0x5600
Hex Value: 0x4006
Hex Value: 0x121A
Hex Value: 0x0EB5
Hex Value: 0x00FF
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 261337 km
Time Indication: 0
Date: 2019.03.30
Time: 17:36:07
Freeze Frame:
Hex Value: 0x1200
Hex Value: 0x4006
Hex Value: 0x120A
Hex Value: 0x46B7
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 261337 km
Time Indication: 0
Date: 2019.03.30
Time: 17:36:08
Freeze Frame:
Hex Value: 0x1200
Hex Value: 0x6206
Hex Value: 0x1216
Hex Value: 0x02B8
Hex Value: 0x00FF
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000095993
Shop #: WSC 00000 000 00000
VCID: 306888EF6330F4BEED-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 238
Mileage: 261337 km
Time Indication: 0
Date: 2019.03.30
Time: 17:36:08
Freeze Frame:
Voltage: 14.80 V
Count: 58
Speed: 18.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
TiitR2
Registreerunud 21.07.04
postitati 31.03.19 12:43 Tsiteeri
Kõik vead on intermittent ehk pole püsivad. Pakun, et kusagil tekkis korraks voolukõikumine (mille iganes pärast) ja salvestas vead mällu. Lase puhtaks ja proovi peale mõningast sõitu uuesti vigu lugeda.
Vaatan, et vead on loetud eile õhtul, seega kui tegid puhtaks, saad täna juba uuesti vaadata.
Meissel2
postitati 31.03.19 13:59 Tsiteeri
Algselt postitas: TiitR2
Lasin need täna järjest kontrollmoodulite alt puhtaks. ja mootorile tuli uus teade: no asam data for ev_ecm30ltdai5 (AU48). Selle kohta ei leidnud mitte midagi.
Aga jah, need eelmised ei ole hetkel veel tagasi tulnud.
Tänan vastamast!
qqaabz
Registreerunud 19.02.15
Auto: Audi A6 C6 3.0TDI
postitati 31.03.19 14:36 Tsiteeri
Algselt postitas: Meissel2
Tänan vastamast!
See on hiina kaabli mure mitte mingi viga.
TiitR2
postitati 31.03.19 15:00 Tsiteeri
Algselt postitas: qqaabz
Tänan vastamast!
Jep, nii tavaliselt on, kuna ei suuda mingit moodulit lugeda (kas on proge vana või kaabel lihtsalt jukerdab).
Meissel2
postitati 31.03.19 17:56 Tsiteeri
Mootori tuli süttis uuesti ning tagasi tulnud viga oli
TiitR2
postitati 31.03.19 18:36 Tsiteeri
See viga oli ka enne olemas ja ainuke, mis polnud intermittent (enne ei pannud tähele).
Kuid lõhnab drosselklapi vahetuse järele.
Meissel2
postitati 01.04.19 12:21 Tsiteeri
Ja täpselt nii ongi. Võtsin ta lahti ja nagu googlest selle kohta pilte nägin, olidki hambad maas.
Meissel2
postitati 05.04.19 09:11 Tsiteeri
Sain drosseliga ühele poole, kuid kõik muud ABS-i, ESP ja Hand break vead tulid tagasi. Kui ära kustutan need, siis mõne ajapärast sõiduajal tulevad tagasi ja väga vaevaliselt liigub edasi nagu tahaks välja surra ning lõpuks sureb ka. Uuesti käima pannes poleks nagu midagi juhtunud, aga vead on mälus ikka olemas.
Päev enne, kui need vead esimest korda välja lõid, käisin ülevaatusel ja no nagu ikka seal ta jauras piduritega. Ehk läks siis midagi rivist välja?
[PHP: 11.7% - SQL: 88.3%]
