Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Tagasillas kolks
Pealkiri: Tagasillas kolks (Vastuseid: 2 | Vaatamisi: 1358)
Roven
Registreerunud 27.07.18
Auto: Audi 100 c4 Quattro avant 2.0 103kw dohc
postitati 05.08.18 16:30 Tsiteeri
Tagasillas kolks
Tervist.
Auto: audi 100 c4 quattro 2.0 103kw dohc
Nimelt kui kohalt võtta või sõiduajal sidurit vajutada ja uuesti lahti lastes (vedu taha lastes) olenematta sõidu kiirusest, käib tagasillas kolks.
Milles võib olla probleem? :)
Olen quattro maailmas uustulia
Retro
Registreerunud 26.02.07
Auto: 2xVW
postitati 05.08.18 19:08 Tsiteeri
Ilmselt tagadiffri lõtk või mõni pooltelje ots lõtkuga.
Eks see häiriv on, aga aeg on oma töö teinud.
Endal sarnane tõks ja tuleb see diffrist, sest seal lõtkud sees.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 06.08.18 11:34 Tsiteeri
Diffri tagumine puks võib ka kobistada. Proovi diffrit tagaotsast tõsta, vaata kas tekib lõtk poolraami ja padja vahele.
[PHP: 9.9% - SQL: 90.1%]
