Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Hübriidturbo ?
Pealkiri: Hübriidturbo ? (Vastuseid: 12 | Vaatamisi: 4939)
rs156
Suletud konto
Registreerunud 24.03.15
postitati 23.07.18 18:04 Tsiteeri
Hübriidturbo ?
Hei,
Kas keegi oskab täpsemalt öelda, mis hübriidturbo ikkagi on?
Netist lugesin, et erinevate turbode osadest või lihtsalt eri-osadest kokku pandud turbo, eks sealt vast ka nimi "hübriid". Ning eesmärk on autole spetsiifiline turbo ehitada, mis töötaks suurema võimsusega kui olemasolev.
Kas ma sain õigesti aru?
Kas selliseid turbosid ehitatakse kõigile mootoritele, bensiin ja diisel?
Kui suur keskmiselt on olemasoleva turboga kasutegur (nt lõppvõimsus vms) ?
Miks seda üldse tehakse kui tehasest tulev turbo on juba just selle auto jaoks ? Või ei ole?
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 23.07.18 18:35 Tsiteeri
Kergem ja suurem billet kompressori ratas üldjuhul. Suurem turbiini ratas. Kodasid freesitakse suuremaks. Pärast vajab auto ka uuesti seadistamist. Tehakse nii bensukatele kui ka diislitele.
postitati 23.07.18 21:01 Tsiteeri
Sinu autol on võimsuse kasvatamiseks vaja 180kw turbo panna. Kõige lihtsam.
rs156
Suletud konto
postitati 24.07.18 05:31 Tsiteeri
Okei, seda on hea teada.
Kui on võimalik igasuguseid turbosid osta, siis miks üldse hübriidturbosid tehakse, mis sellega saavutatakse?
Kui tavalise turbo tegemine ja autole kohandamine on keeruline, kas siis hübriidturbo hind/keerulisus versus kasutegur ei ole paigast?
Kasutaja on foorumis
postitati 24.07.18 06:32 Tsiteeri
Täpselt sama hea on küsida, et miks mõni valib rehviks Pirelli ja teine Conti.
rs156
Suletud konto
postitati 24.07.18 06:34 Tsiteeri
No sorri, kuid ma ei saa aru ja minu arust ei ole päris sama analoogia. Tarbijana on ikka erinev, kas ostan Pirelli või Conti rehvi või lasen mõnel töökojal täiesti uue rehvi tüübi teha enda autole.. Sellest üritangi aru saada, et miks tehakse, ilmselgelt on kallis. Kas kasutegur nii palju suurem muidu kättesaadavatest turbodest ?
postitati 24.07.18 06:59 Tsiteeri
Algselt postitas: rs156
Ma võin küll eksida, aga ma olen aru saanud, et hübriidide ehitamise mõte on saavutada midagi spetsiifilist. Originaal on loodud universaalsena toimima kogu pöörete vahemikus. Hübriidid aga ilmselt selleks, et kas siis saavutada suuremat rõhku või siis, et saavutada rõhk madalamate pööretega just selle konkreetse mootoriga sõltuvalt sellest, milleks autot kasutatakse (erinevad võistlused või tänavasõit jne).
Seega oligi rehvide võrdlus hea. Et ühed sobivad ehk paremini kiireks stardiks ja pidurduseks, teised ehk kurvide kiiremini läbimiseks. "Hübriid" oleks ehk siis midagi vahepealset just spetsiaalselt sellele autole, kus on arvestatud auto massi, silla geomeetriat ja otstarvet milleks autot kasutatakse jne.
rs156
Suletud konto
postitati 24.07.18 07:11 Tsiteeri
Aah.. okei. loogiline. Siis on tõesti rehvi-analoogia hea :)
Kas keegi teab, kas Eestis on hübriidturbod aktuaalne teema või pigem "einoh, mõni teeb.." ?
andrec
postitati 24.07.18 08:27 Tsiteeri
http://turbomotors.ee/turbokompressorite-tuuning/
postitati 24.07.18 08:53 Tsiteeri
Neid tehakse ikka sellepärast, et ei ole võimalik kõike osta.
150kw puhul on lihtne, 180kw puhul on ainus võimalus ulmelisi summasid investeerimata olemasolevaid kodasid freesida ja suuremad tiivikud sisse panna.
andrec
postitati 24.07.18 09:51 Tsiteeri
Jah, lihtsalt suurem turbo osta tuleb ringi teha ka kogu torustik turbo ümber. Hübriidiga pääsed sellest jamast, kuna turbo istub samamoodi tagasi auto külge kust ta tuli.
rs156
Suletud konto
postitati 24.07.18 09:59 Tsiteeri
Päris äge.
Tänud kõigile vastajatele! Jälle targem, huvitav teema.
Järgmisena saab siis muruniidukile hübriidturbot ostma minna. Igaks juhuks mainin, et see on nali :)
Rom
Registreerunud 28.05.05
Auto: C6 3.0TFSI S-line
postitati 24.07.18 12:00 Tsiteeri
Muruniiduk tõuseb lendu sellega, kõlbab ainult puu latvade pügamiseks :)
[PHP: 7.6% - SQL: 92.4%]
