Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 100 automaatkasti probleem
Pealkiri: Audi 100 automaatkasti probleem (Vastuseid: 2 | Vaatamisi: 1549)
Priitv01
Registreerunud 26.06.14
Auto: BMW E36 318i '97
postitati 30.05.18 18:39 Tsiteeri
Probleem Audi 100 automaatkäigukastiga. Autoks täpsemalt siis 03.1990 aasta Audi 100. 2,0 85 kW.
Probleem siis selles, et autol olemas ainult tagurpidi käik. Kõigi edaspidi käikudega auto liikuma ei hakka. Milles võib probleem olla? Tõenäoliselt kastis mingi mehaaniline viga, aga mis täpsemalt? Kang liigub ilusti. Saab selle vea lihtsalt ära lahendada või vaja uut kasti?
Väidetavalt tekkis viga peale süüteluku põhja vahetust, aga see võib olla ka lihtsalt kokkusattumus.
Ehk keegi kokku puutund nendega ja oskab aidata.
Tänades,
Priit
postitati 31.05.18 03:25 Tsiteeri
Kui salongis käigukang ka kasti küljes vastavat hooba kenasti liigutab ja sealt midagi ära pudenenud ei ole, siis pole su kastil mingit probleemi.
Peale selle, et välja on vaja vahetada. Mingi töötava variandi vastu.
Priitv01
postitati 01.06.18 18:21 Tsiteeri
Hoovad liiguvad ilusti kasti küljes. Ka sai kasti karteri põhi maha võetud. Sees ei tundunud liigset metalli puru olema. Kastis sees hoovad liikusid, nii palju kui alt näha oli.
Tagurpidi sõida palju tahad, aga esipidi auto kohe keeldub sõitmast. :D
[PHP: 17.9% - SQL: 82.1%]
