Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi V8 tõmbleb kuumalt
Pealkiri: Audi V8 tõmbleb kuumalt (Vastuseid: 4 | Vaatamisi: 1298)
tambet
Registreerunud 05.10.04
Auto: Audi V8 3.6 '91
postitati 11.07.05 09:33 Tsiteeri
Tere.
Selline jama siis, et praeguste kuumade ilmadega hakkavad aegajalt mootoril tühikäigupöörded kõikuma ( ja hakkab põlema ka hüüumärk armatuuris) , samuti on siis ka
sõites mingitel pööretel jõnksutamine.
See juhtub tavaliselt siis, kui mootor juba kuum ja näiteks peale
korraks kinnipidamist, uuesti käivitades.Ja rohkem nagu siis, kui algul panna tagumine käik sisse.Järjest sõites nagu ei juhtu.
Automaatkasti õli on normis, olen seda pidevalt kontrollinud.
Küll aga kulub natuke mootoriõli ja kuumaga tuleb põhja alt ka
kärsakat - ilmselt siis tagumine simmerling läbi.
Aga ka see saaks siis põhjustada seda muud jama?
Anduritest niiapalju, et lambda sai kuu aja eest Forsis vahetatud, selles ei tohiks viga olla.Pealegi on see jama olnud nii enne kui pärast.Autol on 3.6L mootor .
Mille puhul üldse hüüumärk põlema hakkab?
markoco
Registreerunud 18.09.04
Auto: audi 100
postitati 06.09.05 16:23 Tsiteeri
kas siis ka tõmbleb kui kliima välja lülitad
kasa
Registreerunud 14.03.05
Auto: Audi V8 Q.
postitati 25.09.05 00:42 Tsiteeri
Mul V8 -l sama jama ,mingi 120 pealt aeg-ajalt nagu pooks kinni ja jõnksutab.Kuumalt vahest ei taha mootor korralikult käima ka jääda.
Maqmaq
Registreerunud 30.01.05
Auto: Üks teine auto
postitati 26.09.05 15:11 Tsiteeri
Kas lambda oli originaal või mingi universaal? Kõik kirjeldused samad mis minul olid. Peale lambda vahetust Revalis asi korras. Mingil momendil hakkas hüüumärk põlema ja peale tule süttimist jäi masin seisma. Süüde välja ja uuesti sisse ning auto käivitus uuesti ilma probleemideta.
kasa
Auto: Audi V8 Q.
postitati 28.09.05 09:37 Tsiteeri
Ei oska õelda kas lamda originaal või mingi muu aga kui jõnksutab siis võtab nagu kütet ka topelt palju.Palju see lamda vahetus maksis.
[PHP: 45.7% - SQL: 54.3%]
