Pealkiri: Probleem a8 kliimaga, veakoodid väljatoodud (Vastuseid: 0 | Vaatamisi: 1715)
melkukas
Registreerunud 20.02.08
Auto: audi a8 d3 4.2
postitati 01.03.18 20:04 Tsiteeri
audi a8 d3 2003 4,2 246 kw
Oskab keegi öelda kust ja millega pihta hakata. Sooja salongi põhimõtteliselt ei tule, heal juhul leigeks läheb, keskmistest avadest ei toimu midagi, mootori temp ilusti 90 peal
8 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 53
Reset counter: 14
Mileage: 334382 km
Time Indication: 0
Date: 2017.11.18
Time: 20:18:34
Freeze Frame:
Voltage: 13.70 V
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 104
Reset counter: 229
Mileage: 334383 km
Time Indication: 0
Date: 2017.11.19
Time: 01:56:57
Freeze Frame:
Voltage: 13.30 V
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 14
Mileage: 334425 km
Time Indication: 0
Date: 2017.11.19
Time: 13:46:40
Freeze Frame:
Voltage: 13.30 V
Temperature: 13.0°C
(no units): 60.0
(no units): 95.0
Temperature: -91.0°C
00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 250
Mileage: 334581 km
Time Indication: 0
Date: 2017.11.25
Time: 18:07:13
Freeze Frame:
Voltage: 13.30 V
Temperature: 2.0°C
(no units): 60.0
(no units): 95.0
Temperature: -99.0°C
01868 - Rear Right Warm/Cold Flap Air Outlet Motor (V221)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 250
Mileage: 334645 km
Time Indication: 0
Date: 2017.11.30
Time: 11:37:01
Freeze Frame:
Voltage: 13.30 V
Temperature: 1.0°C
(no units): 60.0
(no units): 95.0
Temperature: -98.0°C
01852 - Position Sensor; Defrost/Upper Body Shut-Off Flap Motor; Left Front (G318)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 10
Mileage: 335330 km
Time Indication: 0
Date: 2017.12.10
Time: 23:46:15
Freeze Frame:
Voltage: 13.70 V
(no units): 239.0
(no units): 255.0
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Mileage: 335461 km
Time Indication: 0
Date: 2017.12.15
Time: 19:55:24
Freeze Frame:
Voltage: 13.80 V
(no units): 136.0
(no units): 0.0
00565 - Rear A/C Control Head (Climatronic) (E265)
013 - Check DTC Memory
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Mileage: 335461 km
Time Indication: 0
Date: 2017.12.15
Time: 19:55:24
[PHP: 11.3% - SQL: 88.7%]
