Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A6 C6 3.0tdi 171kw hommikune kigin.
Pealkiri: A6 C6 3.0tdi 171kw hommikune kigin. (Vastuseid: 14 | Vaatamisi: 2400)
kresetnjak
Registreerunud 11.01.18
Auto: Audi S6 C7 4.0 V8 396kw
postitati 26.02.18 13:31 Tsiteeri
Tere.
Võibolla ei ole just suurem probleem kuid kuna olen alles värske omanik siis tekib ikka küsimusi.
Ühesõnaga olen viimased päevad kui hommikuti on -15 kraadi jne siis peale käivitust on paras kigin kuskil max 5 sekundit.
Kas asi on rihmapingutis? või on veel miskit mis seda tekidada võib?
Seda juhtub vaid hommikul esimesel käivitamisel ja siis kui ikka külma üle -10 vähemalt. Edasi pole päeva jooksul täheldanud seda häält.
Suur tänu kõigile kaasamõtlejatele ja vastajatele.
postitati 26.02.18 14:09 Tsiteeri
Normaalne see pole, väljend kigin on väga üldine, seega pead kellegil kes midagi reaalselt teab neist mootoreist kuulata laskma. Kett teeb pigem kõrinat mitte kiginat :D
kresetnjak
postitati 26.02.18 14:39 Tsiteeri
Ketiga see kigin vaevalt seotud on sest see hääl tuleb ikka mootori eest otsast.
genekas roolivõim ja kõik jooksevad eest ju ühe rihmaga eks? igatahes kuskilt sealt see kigin tuleb aga ennem kui saad aru täpselt kuskohast on vaikus ja kõik. endale tundus et hääl jäi rohkem juhipoolsesse äärde.
Raske on ka kellegile seda kuulata lasta kui seda tekib vaid peale öö otsa seismist ja kõvema miinus kraadiga. kui selline -12 ja soojem oli siis polnud midagi kuulda.
Stych
Registreerunud 19.10.13
postitati 26.02.18 15:56 Tsiteeri
Olen ise ka värske a6 omanik nüüd ja minu omal on täpselt sama asi küljes julgen pakkuda. Mootoriks küll 2.7TDI aga see ju pmtl sama asi. Minu omal on asi igatahes mingis rullikus. Kui mootor väga kurjaks ajada siis on sõidu ajal kõrgetel pööretel ka kuulda, et mingi rullik ei ole kõige paremas seisukorras. Nädalalõpus tegelen sellega siis võin raporteerida. Sitt uudis on see, et ilmselt tuleb nina eest nihutada, et seal kuhugi normaalselt ligi pääseda.::(
audisell
Registreerunud 06.01.09
postitati 26.02.18 16:04 Tsiteeri
Siin teemas lahatud probleemi, ehk abiks http://foorum.audiclub.ee/viewthread.php?tid=105339&page=1&highlight=rooliv%F5imu%20l%F5dvik#pid740590
Stych
postitati 26.02.18 16:24 Tsiteeri
Tuli meelde, et tegin isegi kiire video hommikul käivitamisest kui väljas -22 oli. Ilmselt tuleb see ikka roolivõimupumbast siis kui seda teemat lugeda.
https://drive.google.com/open?id=1rLoKynQlqeYzqJk5WVDnrCy0sZwtIK63
kresetnjak
postitati 26.02.18 18:20 Tsiteeri
Algselt postitas: Stych
Ok peale selle video vaatamist/kuulamist olen 99% kindel et roolivõim teeb seda häält. Tsekin õlitasemed ja asjad üle aga nagu aru saan siis muud väga teha pole.
Amadeus
Registreerunud 08.10.02
postitati 26.02.18 18:43 Tsiteeri
Algselt postitas: kresetnjak
Võid proovida ka õlivahetust. Kindlasti tuleb sinna sisse valada ikka õige vedelik.
Õlipaagi imitorul peaks olema peenike sõel ees, selle võiks kah igaks juhuks üle vaadata.
kresetnjak
postitati 26.02.18 18:59 Tsiteeri
Algselt postitas: Amadeus
Järgmisel nädalal plaanis nkn minna ketikaane tihendeid vahetama siis lasen selle õli ka ära vahetada juba. tänud.
kresetnjak
postitati 28.02.18 16:06 Tsiteeri
nagu ma aru saan targast interneedusest siis roolivõim tahab G 002 000 õli või CHF 11s?
Kas peale esinduse ka keegi neid müüb? automaailm jne jne
Ning mis liitri hind ka on?
postitati 28.02.18 16:24 Tsiteeri
G002000 on vana kood ja vist sellega enam ei leia. G004000 on uus, autopoed soovitavad inimestele tavaliselt sünti oma kataloogide järgi, mina paneks rohelist mineraali, Febi pakendatud näiteks. Valge purk rohelise korgiga, liitri hind jäi alla 10 eur, kui õigesti mäletan.
rendoqoz
Registreerunud 22.04.10
postitati 28.02.18 16:55 Tsiteeri
https://aeromotors.ee/kataloog/search/99906161/
Äärmiselt odav.
kresetnjak
postitati 28.02.18 17:19 Tsiteeri
Tänud. Lähen vuran homme hommikul automaailmast läbi ja uurin mis neil pakkuda on.
Amadeus
postitati 28.02.18 17:52 Tsiteeri
Mina soovitan sisse valada seda, mida pott ja tootja soovitab. Igasugune suvaline kasemahl, tekitab korraliku salati kapoti all. Paar € kokkuhoidu ei vääri seda.
Loe läbi ka see teema: http://foorum.audiclub.ee/viewthread.php?tid=64119
kresetnjak
postitati 28.02.18 18:17 Tsiteeri
ok tänud.
Lähen homme vaatan üle mida pott tahab. tean et õli tase on miinimumi peal ja nüüd -20 ma seda kortermaja ees küll ei taha vahetama kohe hakata.
pm kui pott nõuab mineraali siis seda võiks ju juurde ka kallata kuni järgmine nädal nkn lähen töökotta?
[PHP: 13.5% - SQL: 86.5%]
