Pealkiri: vcds iga abi vaja koodidega tartus. (Vastuseid: 11 | Vaatamisi: 4196)
oll555
Registreerunud 08.02.06
postitati 21.01.18 11:03 Tsiteeri
Auto a6 4f 3.0 165kw
Olemas proge.arvuti ja kaabel 15.7...
Äkki keegi pädev viitsib aitata mingi raha eest.
Minul aega täna ja nädalasees peale kaheksat.
Tartu ning tl.82004949
TiitR2
Registreerunud 21.07.04
postitati 21.01.18 11:11 Tsiteeri
Aga pista kaabel sappa ja postita veakoodide väljatrükk siia?
oll555
postitati 22.01.18 17:37 Tsiteeri
Sunday,21,January,2018,21:19:22:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WAUZZZ4F26N162000 License Plate: VOL 1
Mileage: 369390km-229528mi Repair Order: 21.01.2018
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 18 19 34 36 37 3D
42 46 47 4F 52 53 55 56 57 61 62 69 72 76 77
VIN: WAUZZZ4F26N162138 Mileage: 369390km-229528miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
3D-Special Function -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Not registered 0001
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F0 910 401 S HW: 4F0 907 401 C
Component: 3.0L V6TDI A011AG 0030
Revision: --H02--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 2C509C9F8F18905ED1-8078
3 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:45:34
Freeze Frame:
RPM: 777 /min
Torque: 50.7 Nm
Speed: 0.0 km/h
Voltage: 13.76 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
005747 - Speed Signal
P1673 - 003 - Malfunction Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 0
Fault Frequency: 36
Reset counter: 255
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:51:01
Freeze Frame:
RPM: 777 /min
Torque: 81.9 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 17.86 V
Bin. Bits: 00110000
Torque: 249.6 Nm
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368596 km
Time Indication: 0
Date: 2018.01.16
Time: 19:26:13
Freeze Frame:
RPM: 1722 /min
Torque: 0.0 Nm
Speed: 98.6 km/h
Duty Cycle: 1.0 %
Duty Cycle: 39.8 %
(no units): 0.0
(no units): 16.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 S HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0030
Revision: --H01--- Serial number: 0000999
Coding: 0000001
Shop #: WSC 40690 150 63919
VCID: 346084FF5728C89E89-8060
1 Fault Found:
001379 - System Voltage
P0563 - 000 - Too High - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 19:09:55
Freeze Frame:
RPM: 832 /min
RPM: 800 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 42.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 C HW: 4F0 614 517 C
Component: ESP 8.0 quattro H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0004492
Shop #: WSC 76139 146 59725
VCID: 244074BFE7C8581E19-8070
2 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 50
Reset counter: 186
Mileage: 368681 km
Time Indication: 0
Date: 2018.01.17
Time: 07:39:03
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x5382
Hex Value: 0x0007
Hex Value: 0xB090
Hex Value: 0x00FF
00532 - Supply Voltage B+
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 8
Reset counter: 226
Mileage: 369000 km
Time Indication: 0
Date: 2018.01.18
Time: 20:04:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x0003
Hex Value: 0x22D3
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10604000290853
Coding: 0000135
Shop #: WSC 26832 136 80354
VCID: 63C237A3A2461F2620-8036
Subsystem 1 - Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
1 Fault Found:
00447 - Function Limitation due to Over-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 224
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 19:09:55
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory BFS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0070752
VCID: 61CE3DABB85A0D3632-8034
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 224
Mileage: 106440 km
Time Indication: 0
Date: 2018.01.16
Time: 19:10:18
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 351CP067515638
Coding: 0001202
Shop #: WSC 00000 000 00000
VCID: 26446EB791F4AA0E07-8072
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000356773
Subsystem 3 - Serial number: 0107.03.060000000100010547˙
Subsystem 4 - Serial number: 010547˙
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Mileage: 368761 km
Time Indication: 0
Date: 2018.01.17
Time: 11:29:55
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
Shop #: WSC 02335 785 00200
VCID: 2A5C9A8785EC8E6E23-807E
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00022800
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00150608
Shop #: WSC 02335
No fault code found.
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8073042
VCID: 1C304C5FDFB860DEA1-8048
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1229T8200686
Coding: 0000001
Shop #: WSC 02331 785 00200
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH02 0020
Revision: -------- Serial number: 00000000000000
Coding: 0031168
Shop #: WSC 76032 146 59725
VCID: 234277A3E2C65F2660-8076
5 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 54
Reset counter: 186
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:47:10
Freeze Frame:
Temperature: 1.0°C
Voltage: 13.44 V
Bin. Bits: 00000
Hex Value: 0x2513
Hex Value: 0x0002
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 173
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:47:10
Freeze Frame:
Temperature: 1.0°C
Voltage: 13.44 V
Bin. Bits: 00000
Hex Value: 0x2A41
Hex Value: 0x0006
Speed: 0.0 km/h
02002 - Heater for Distance Regulation Sensor (Z47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 9
Reset counter: 184
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:50:16
Freeze Frame:
Temperature: 1.0°C
Voltage: 12.80 V
Bin. Bits: 00000
Hex Value: 0x2A11
Hex Value: 0x0002
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 39
Reset counter: 226
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:51:00
Freeze Frame:
Temperature: 1.0°C
Voltage: 17.66 V
Bin. Bits: 00000
Hex Value: 0x0055
Hex Value: 0x0005
Speed: 0.0 km/h
Lateral Accel.: 1.75 m/s^2
01315 - Transmission Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 219
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 19:09:56
Freeze Frame:
Temperature: 1.0°C
Voltage: 12.93 V
Bin. Bits: 00000
Hex Value: 0x2514
Hex Value: 0x0001
Speed: 82.8 km/h
Lateral Accel.: -6.37 m/s^2
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 43 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0ZJY03
Coding: 0013363
VCID: 295E658B80EA85762A-807C
Subsystem 1 - Serial number: 6332CSME0D171517$
Subsystem 2 - Serial number: 6342CSME0D166010W
Subsystem 3 - Serial number: 6352QSME0B6B2005C
Subsystem 4 - Serial number: 6362QSME0B54273BL
Subsystem 5 - Serial number: 63734SME1509090AZ
Subsystem 6 - Serial number: 63834SME75190810X
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025060550021
Coding: 0002152
VCID: 66C42EB751746A0EC7-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 224
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 19:10:18
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 D
Component: KOMBIINSTR. M73 H17 0660
Revision: 00200000 Serial number: 4R052R036
Coding: 2177003
Shop #: WSC 00999 444 64523
VCID: 214E7DABF8DA4D3672-8074
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 A HW: 4F0 265 081 L
Component: Heizgeraet H08 0060
Revision: B Serial number: 09011480
Coding: 0000111
VCID: 1B324F43DAB667E6A8-804E
2 Faults Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 222
Mileage: 369019 km
Time Indication: 0
Date: 2018.01.19
Time: 07:19:50
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 224
Mileage: 369373 km
Time Indication: 0
Date: 2018.01.21
Time: 12:23:11
Freeze Frame:
After-Run
Temperature: 73.0°C
Temperature: 62.0°C
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 E
Component: Gateway H11 0070
Revision: 11 Serial number: 12009059088066
Coding: FFFE7BDE1B3904
VCID: 275A63B396FEB3063C-8072
3 Faults Found:
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 173
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:50:20
00380 - Special Vehicle Control Module (J608)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 173
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:50:21
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 59
Reset counter: 186
Mileage: 368584 km
Time Indication: 0
Date: 2018.01.16
Time: 18:50:25
Address 34: Level Control
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H04 0050
Coding: 0066666
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 224
Mileage: 106440 km
Time Indication: 0
Date: 2018.01.16
Time: 19:10:18
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H47 1060
Revision: 00000000 Serial number: 364C-067537578
VCID: 3B72AFC37A7607E648-806E
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 226
Mileage: 369000 km
Time Indication: 0
Date: 2018.01.18
Time: 20:04:58
Freeze Frame:
Hex Value: 0x5A64
Hex Value: 0xF53F
Hex Value: 0x00AD
Address 3D: Special Function
Cannot be reached
Address 42: Door Elect, Driver Labels: None
VCID: 55A6197BBC12F1965E-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01011234560000
Coding: 0402161
VCID: 2E549697B904E24EFF-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
3 Faults Found:
02932 - Control Circuit for Brake Light in Trunk/Hatch Lid; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 127
Reset counter: 186
Mileage: 368233 km
Time Indication: 0
Date: 2018.01.15
Time: 02:51:56
02930 - Control Circuit for Brake Light in Fender; Right
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 225
Mileage: 368693 km
Time Indication: 0
Date: 2018.01.17
Time: 08:13:26
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 170
Mileage: 368327 km
Time Indication: 0
Date: 2018.01.15
Time: 06:23:52
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000211167
Coding: 0000112
VCID: 254669BBECF2A1160E-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000202984
Coding: 0001113
VCID: 5EB40657892432CE0F-800A
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 262136 km
Time Indication: 0
Date: 2018.01.16
Time: 19:10:00
Freeze Frame:
Voltage: 13.400 V
Temperature: 0.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 224
Mileage: 262136 km
Time Indication: 0
Date: 2018.01.16
Time: 19:09:00
Freeze Frame:
Voltage: 17.300 V
Temperature: 77.0°C
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 A HW: 4F0 907 801
Component: EPB CA3C0040 H03 0040
Revision: --H03---
Coding: 0000321
Shop #: WSC 02324 785 00200
VCID: 1E344657C9A472CE4F-804A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 226
Mileage: 368656 km
Time Indication: 0
Date: 2018.01.16
Time: 21:04:51
Freeze Frame:
Voltage: 12.73 V
Count: 236
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Coding: 0000003
VCID: 3A7CAAC7754C3EEE53-806E
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352CX067629279
Coding: 0000001
Shop #: WSC 67867 403 00200
VCID: 316E8DEBA83AFDB6E2-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H05000 Serial number: 76300700147901
Coding: 0000301
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000031408
Shop #: WSC 12345 384 00290
Subsystem 1 - Part No: 4F0 915 181 A
Component: von VA0 0199000013
Coding: 344630393135313831412056413030313939303030303133
5 Faults Found:
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 213
Mileage: 368681 km
Time Indication: 0
Date: 2018.01.17
Time: 04:02:25
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 369087 km
Time Indication: 0
Date: 2018.01.19
Time: 18:34:44
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 369090 km
Time Indication: 0
Date: 2018.01.19
Time: 18:49:21
02254 - Interface to Generator
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 369364 km
Time Indication: 0
Date: 2018.01.21
Time: 02:35:20
02479 - Partial Consumer Shut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 369365 km
Time Indication: 0
Date: 2018.01.21
Time: 02:39:52
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0017454
Shop #: WSC 02327 785 00200
Address 69: Trailer (J345) Labels: 4F0-907-383.clb
Part No SW: 4F0 907 383 D HW: 4F0 907 383 D
Component: Anhaenger H08 0080
Revision: 2B002002 Serial number: 00000117291487
Coding: 0100000000000000
Shop #: WSC 38059 136 90453
VCID: 2C509C9F4F18905ED1-8078
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0017454
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 E HW: 4F0 919 283 E
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820606201678
Coding: 0201116
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 224
Mileage: 369373 km
Time Indication: 0
Date: 2018.01.21
Time: 12:22:57
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007548472
Coding: 0010920
Shop #: WSC 00064 264 90879
End-------------------------(Elapsed Time: 04:20)--------------------------
TiitR2
postitati 22.01.18 18:16 Tsiteeri
Suures osas viitavad vead akule ja/või generaatorile. Ja kuni sealt hakkavad kõikumised või hälbed, siis virutab igale poole vigu sisse.
Lisaks lambda, ABS-i anduri, jne...
yanekk
postitati 22.01.18 18:18 Tsiteeri
Vaheta/kodeeri aku, vaheta mootoripadi ja abs andur alustuseks ära, saad pildi oluliselt puhtamaks.
Best ET 12.08 :)
txxxl
Registreerunud 22.11.11
Auto: Audi
postitati 22.01.18 18:30 Tsiteeri
Äkki testiks akut enne vahetamist ja mõõdaks laadimis pinge ära.
tl470487
aeg maha
Registreerunud 06.07.11
postitati 22.01.18 18:41 Tsiteeri
Mis tehti 19:09, et pinge 17,3V ja temp 77C ?
Samas 19.10 on pinge 13,40V ja temp 0C
Selle kirje põhjal tekib kahtlus, et mingi erilise boosteriga on autot käivitatud?
Vead kustutada ja siis süveneda. Enamusele koodidele on vastused RT wiki-s: http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Algselt postitas: oll555
Coding: 0001113
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 262136 km
Time Indication: 0
Date: 2018.01.16
Time: 19:10:00
Freeze Frame:
Voltage: 13.400 V
Temperature: 0.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 224
Mileage: 262136 km
Time Indication: 0
Date: 2018.01.16
Time: 19:09:00
Freeze Frame:
Voltage: 17.300 V
Temperature: 77.0°C
oll555
postitati 22.01.18 20:07 Tsiteeri
See tralm hakkas siis.kui geneka harjad alla andsid.Sai vahetatud harjad ja p.regulaator.
Aku ok ja kodeeritid.Autol pinge millegipärast kõigub.Põhjus teadmatta.
TiitR2
postitati 22.01.18 20:21 Tsiteeri
Mul Tartus toimiv genakas olemas, küll Phaetoni pealt, kuid sama motoga, kui peaks sobima? Vesijahutusega sul ikka?
Minu oma pealt nr. viitab küll 4.2 mootoriga bensuka A8 peale, samuti 5.0d Touaregile?
oll555
postitati 22.01.18 20:23 Tsiteeri
Teeb sellist triki ka.et suvalisel ajal lööb kõik pimedaks ja kohe pilt uuesti ees.Väga harva ka nii.et käigukasti kõik asendid punased kelladel .Siis lülitab käigukastk n asendksse.Keera teearde süüde valja ja uuesti auto käimapannes jälle kõik korras...Minujaoks müstika veits.
oll555
postitati 22.01.18 20:25 Tsiteeri
Genekas ok ja vaeno 180a.
postitati 23.01.18 04:09 Tsiteeri
Geneka interfeiss on pees, tuleks ikka osata asju lähemalt vaadata 61 alt, et päris kindel olla. Hüppenööri ostmine ja veakoodide lugemine ei vii tavaliselt edasi, kui asju tólgendada ei oska. Distronicu soojendus kodeeri maha, hakkab tööle. Vói pane uus, 2min töö.
Kui need asjad tehtud, puhastad veamälu, vaatad vigase abs sensori üle vajadusel. Siis selgub mis veel.
[PHP: 24.0% - SQL: 76.0%]
