Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 15" veljed B3-le
Pealkiri: 15" veljed B3-le (Vastuseid: 6 | Vaatamisi: 1835)
poison
Registreerunud 21.09.05
Auto: Audi 80
postitati 06.11.17 18:42 Tsiteeri
15" veljed B3-le
Kas B4 veljed istuvad üks-ühele B3-le eeldusel, et auguvalem ja keskava mõõt on samad?
indreks
Registreerunud 01.03.17
Auto: B3 1989
postitati 06.11.17 19:44 Tsiteeri
Algselt postitas: poison
ma ei kujuta ette mis näitaja seal peale nende veel mööda panna annab..
aixx
Registreerunud 21.03.05
postitati 06.11.17 19:48 Tsiteeri
Kui ET on väga väike, siis need rehvid mis b3-l käivad juba vastu koopaäärt, mahuvad b4-ja alla veel ilusasti ära.
poison
Auto: Audi 80
postitati 06.11.17 22:28 Tsiteeri
Ok. Ma olen rahuldatud.
end3l
Registreerunud 27.06.07
postitati 06.11.17 23:24 Tsiteeri
Milleks B3'le B4 velgi alla panna, kui kolmel on endal ka piisavalt ilusaid originaal 15" leida?:D
http://endel.planet.ee/S4/90/doonoriga.jpg
poison
Auto: Audi 80
postitati 07.11.17 21:06 Tsiteeri
milleks postitada?
indreks
Auto: B3 1989
postitati 08.11.17 13:53 Tsiteeri
Algselt postitas: aixx
Tänud, hea teada. Siis leiaks rohtu kõrgemast ja jäigemast vedrust :D
[PHP: 9.9% - SQL: 90.1%]
