Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi a6 3.0 Tdi quattro 2007 171Kw.Õhkvedrustus problem
Pealkiri: Audi a6 3.0 Tdi quattro 2007 171Kw.Õhkvedrustus problem (Vastuseid: 6 | Vaatamisi: 3542)
karvass
Registreerunud 17.12.07
postitati 09.10.17 18:35 Tsiteeri
Kalibreerimise käigus tuli.
https://www.youtube.com/watch?v=jAH-OsCWDX8
4 Faults Found:
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 272442 km
Time Indication: 0
Date: 2006.11.23
Time: 12:56:37
Karel
karel.kala@mail.ee
Nr.53737663
Silverpm
Registreerunud 06.04.08
postitati 09.10.17 19:21 Tsiteeri
Kui kalibreerimise käigus, otsida uuesti tasane pind ja korrata protsessi.
postitati 10.10.17 03:30 Tsiteeri
Miks ülejäänud vigu siia ei copynud? Arvatavasti mingi anduri parameetrid väljaspool piire ja nii tõesti ei saa seda tegevust lõpuni viia. Juhiuks oli kinni?
karvass
postitati 10.10.17 03:45 Tsiteeri
Address 34: Level Control Labels: None
Control Module Part Number: 4F0 910 553 B HW: 4F0 907 553 A
Component and/or Version: J197 LUFTFEDER H17 0020
Software Coding: 0000210
Work Shop Code: WSC 79588 150 84696
VCID: 23450907E2202306A91-8076
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 272442 km
Time Indication: 0
Date: 2006.11.23
Time: 12:56:37
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 272442 km
Time Indication: 0
Date: 2006.11.23
Time: 12:56:37
01583 - Leak in System Detected
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 231
Mileage: 272459 km
Time Indication: 0
Date: 2006.11.23
Time: 16:16:48
02646 - Plausibility of Level Control System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 272469 km
Time Indication: 0
Date: 2006.11.23
Time: 17:07:53
postitati 10.10.17 06:03 Tsiteeri
Vaata kõrgusandurite parameetrid üle, kui auto sirgel pinnal ja kõrgus enam-vähem ühtlane. Kui üks paneb segast, ei saagi teha kalibreerimist.
Veakoodina see ei väljendugi tavaliselt. Kui ei oska, pöördu targemate poole.
karvass
postitati 26.10.17 14:29 Tsiteeri
Viga leitud kompressor ei jõua survet üles taguda.Kompressor maha ja remonti.
aadumees
Registreerunud 23.08.13
postitati 26.10.17 18:56 Tsiteeri
Võimalik, et ma ei saa pihta mida sa teed. Aga kiika siia: http://www.ross-tech.com/vag-com/cars/levelcontrol.html
[PHP: 11.3% - SQL: 88.7%]
