Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi a6 c6 v.e rattast vilin
Pealkiri: Audi a6 c6 v.e rattast vilin (Vastuseid: 2 | Vaatamisi: 1595)
Pontsik
Registreerunud 13.05.13
postitati 08.09.17 19:48 Tsiteeri
Peale klotside vahetust on selline asi tulnud, et sõites hakkab midagi vilisema ratta juurest, kui pidurit vajutada kaob vilin ära, kui lahti lasta pidur, tuleb tagasi vilin.
HangOver
postitati 08.09.17 21:08 Tsiteeri
Kas üks piduri trumlitest ei lähe sõites kuumemaks kui teised? Klots nagu kinni ma arvan...
postitati 09.09.17 08:18 Tsiteeri
No tõsta see nurk kasvõi tungiga üles, võta ratas alt ja keeruta rummust ringi, siis ju näed ja kuuled, mis ja kuhu vastu käib.
Keegi kuratki ei oska ju selgeltnäha, millise pidurpleki või vedru sa kuhugi valesti tagasi pistsid....:P
Või kui lasid kellelgi teisel teha, siis mine ja kurda muret ja vaadatakse üle.
[PHP: 15.4% - SQL: 84.6%]
