Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi B7 2006a esituled vilguvad
Pealkiri: Audi B7 2006a esituled vilguvad (Vastuseid: 4 | Vaatamisi: 1773)
Purified
Registreerunud 11.02.17
postitati 03.09.17 17:46 Tsiteeri
Tere,
Tegemist on orginaal esituledega(mootoriga) kus on orig. xenon pirnid.
Mis vahe on D1S+ P21W ja lihtsalt D1S pirnide tähisel?
Kas pidev vilkumine on põhjustatud pirnide vananemisest?
TSks
Registreerunud 06.01.17
postitati 03.09.17 17:59 Tsiteeri
P21W mis sa mõtled, on tavaline suunatule pirn (kui mõelda esituld)
D1S xenon pirn on ikka xenon pirn, ning mõni teise tähisega ei sobi asendada.
Vilkumisega seoses 2 võimalust: kas ballast hakkab lõppema või pirn. Ballasti viga sellisena väga ei usu aga võibolla võimalik.
Kunagi on sooviatud siis foorumis testida: testida teist xenon pirni (V-P) või ka ballastit (kuid selle testimine pidi olema B7 juures pikem töö// esistange eemaldamine jne.)
Audi B6
jaiks
Registreerunud 21.02.11
postitati 03.09.17 18:27 Tsiteeri
Siin sama teema lahatud veidi
http://foorum.audiclub.ee/viewthread.php?tid=174742&page=1&highlight=d1s#pid831026
D1s on bixenon, d2s on tava xenon ja p21w on päevasõidu pirn samas tules.
aadumees
Registreerunud 23.08.13
postitati 04.09.17 11:31 Tsiteeri
Kõik ksenoonlambid on "bi" funktsionaalsusega ehk töötavad lähi- kui ka kaugtuledena.
jaiks
postitati 04.09.17 11:50 Tsiteeri
Algselt postitas: aadumees
Õigus, tulest oleneb, mitte pirnist, kas bi või mitte.
[PHP: 14.4% - SQL: 85.6%]
