Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 B6 roolilati mure
Pealkiri: A4 B6 roolilati mure (Vastuseid: 1 | Vaatamisi: 1361)
Tarmok
Registreerunud 25.01.10
Auto: A4, 03, 1.9TDI
postitati 16.08.17 10:45 Tsiteeri
Tervitus, mure selline, et pean miskit roolilatiga ette võtma. Nimelt kolksub ning Forssist tuvastati ka, et veaks just roolilatt.
Uurin ise neid lattide hindu ning vähemalt esmapilgul kõiguvad uute lattide hinnad ladu24.ee põhjal seal 300-600 EURini. Kas teab keegi rääkida kas ja mis seal niipalju erinevat on, kas võiks mõelda odavama otsa lati ostmisele või tuleks sellest just eemale hoida? Äkki taastatakse hoopis vanu kuskil või saab kuskilt osta soodsamalt just näiteks taastatud kujul või on mõni muu hea soodsam lahendus välja pakkuda? Ühesõnaga, igasugused soovitused kuidas probleem võimalikult soodsalt, kuid siiski korralikult ära lahendada, on teretulnud :)
teet82
Registreerunud 17.11.13
postitati 16.08.17 18:15 Tsiteeri
Usun, et need 300-600EUR latid on ka tegelikult taastatud, sest tavaliselt peab ju vana tagasi viima poodi. Üks tuttav käis just Automaailmas küsimas C5 A6 jaoks ja hinnaks öeldi vist 560 ja pärast saab 200 tagasi vana eest kui on taastatav, ehk siis 360EUR tuleks hind.
[PHP: 14.5% - SQL: 85.5%]
