Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A6 C5 2.5tdi 110kw ei käivitu
Pealkiri: A6 C5 2.5tdi 110kw ei käivitu (Vastuseid: 3 | Vaatamisi: 1306)
taavi123
Registreerunud 02.07.17
postitati 02.07.17 09:04 Tsiteeri
Tean, et sellise pealkirjaga teemasi on palju, kuid neid lugedes ei ole veel selgusele jõudnud.
Mure siis ikka tavaline: Sõitis ja käivitus ilusti (soojalt vähekene pikemalt). Ühel hommikul enam ei käivitunud.
Nagu teada siis tüüpilisemateks vigadeks on õhk süsteemis või kõrgsurvepump.
Kuna paak on rohkem kui pooltäis ja pumba töötamist on kuulda, siis pagisisese pumba viga ei tohiks olla.
Filtrist pumbani minev pealevoolu voolik on läbipaistev ja seal õhumulle pole.
Kaitsmed vaatasin ka üle.
Tahaks teada, mida veel kontrollida ja kuidas teha kindlaks kas läbi on pump ise, pumba elektroonika(aju) või hoopis midagi muud.
Tänan juba ette neid kes diagnoosimisega ja juhendamisega aidata viitsvad. :cool:
taavi123
postitati 04.07.17 18:22 Tsiteeri
Sai täna autoga tegeletud:
Esmalt kontrollisin paagipumba ja sellejuures oleva anduri anduril oli takistus ja juhe sellejuurest sai parandatud kuna oli oksüdeerunud.
See tulemust ei andnud, edasi juhtisin kütuse filtri juurest lehtriga pumbani, ja keerasin pihustite juurest natuke lõdvemask, õhku pumbas ja voolikutes ei tuvastanud ,sest kütus tuli ilusti pihutiteni ja õhumulle ei tulnud, survet justkui oli sest ühe ülevoolu vooliku juures oli voolikus imepisike auk kust hakkas kütust pritsima. vahetasin vooliku välja, aga endiselt tulemust ei andnud.
Kas keegi oskab selle info põhjal öelda, mis koht vigane on või, mida edasi kontrollida?
urki
Registreerunud 31.01.11
Auto: MB 212 3,5 TDI,MB 212 CNG,A4 Q
postitati 05.07.17 14:05 Tsiteeri
Lase arvuti taha panna ja viga kohe teada siis.
taavi123
postitati 06.07.17 07:25 Tsiteeri
Nii siinkohal paluks klubiliste abi, et kas keegi laenaks kaablit või teaks soovitada kedagi, kes Tartus hea hinna eest veakoodid üle vaataks?
[PHP: 12.3% - SQL: 87.7%]
