Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kapotitross
Pealkiri: Kapotitross (Vastuseid: 3 | Vaatamisi: 1261)
pokerpig
Registreerunud 17.01.16
Auto: AUDI 80 2.0 85kw
postitati 12.06.17 11:24 Tsiteeri
Kapotitross
Kapoti ei avane
Kinniti vms katki kuna parem kapoti pool tuleb, aga vasak ei tule, keegi oskab Tallinnas head kohta soovitada kes teevad mul kapoti lahti? Autoks Audi 80 b4
J.Aru
Registreerunud 28.07.12
postitati 12.06.17 12:54 Tsiteeri
Kas see ei aita kui keegi kapotile peale vajutab sel ajal kui kapoti proovida avada?
postitati 12.06.17 13:16 Tsiteeri
Tasub proovida jah peale suruda samal ajal. Sest kui tross katki on, ei avane kumbki pool. Muidu lukkudele pääseb ilusti ligi, kui stange või kapotivõre eemaldada. Ise olen stange eemaldanud, kuna võre ei saa tervelt kätte, kui kapott suletud. Stanget pole raske eemaldada.
ivorturb12
Registreerunud 21.10.08
postitati 12.06.17 18:36 Tsiteeri
2.0 mootoriga b4-l oli sama probleem, et juhipool ei tulnud enam lahti. Koos põhjakatte alt võtmisega läks kõige maksimum 10minutit ja sai altpoolt juhipoole ka lahti lükata.
[PHP: 21.1% - SQL: 78.9%]
