Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mootor tõmbleb 3.0TDI 165kw
Pealkiri: Mootor tõmbleb 3.0TDI 165kw (Vastuseid: 4 | Vaatamisi: 1884)
qqaabz
Registreerunud 19.02.15
Auto: Audi A6 C6 3.0TDI
postitati 30.04.17 21:04 Tsiteeri
Mureks siis mootori tõmblemine mis algas eilsest ja seisneb selles, et kui sõidan mootori temp ca 80ni ja siis kasti P pealr panen hakkavad pöörded järsku 200pööret ülessr-alla tõmblema ja lööb läbi kere kohe endal, selline jube tõmblemine kohe. (Pihustid tutikad peal 2000km sõitnud ja kodeeritud).
Täna läksin siis arvutiga kallal, et ehk saab mingit aimdust asjast, örnalt mingi 30pööret üles-alla tõmblea ja kerge nõksutsmine nagu oli aga ei midagi erilist ega sellist mis eelpool mainitud. Veakood 0, hakkasin siis vaatama drosseli tööd, korras ei mingeid kõrvalekaldeid, EGR klapp liikus toimis kenasti (soe idle oli mis peaks olema ja mis tegelikkuses oli, oli vahe 40Mg/Str), pöördklapid toimisid korrektselt, DPF oli ilusti tühjaks end ajanud, seal oli mingi 3g sooti, Küttesurveid jälgisin nii koha peal kui ka sõidu ajal (kohapeal mis peaks olema ja mis tegelikkuses, siis tegelikkuse oma hüppas sellest mis olema peaks 7bar ülesse ja siis 7bar alla, siuke kerge kõikumine mis ei tohiks ka midagi hullu olla kuna 20bari kõikumist on ok)? Külma ja sooja mootoriga idle smooth kõik praktiliselt 0,00-0,30 ja niikuinii on uued pihustid siis selles ei saa asi olla.
Täitsa müstika kohe, milles kala olla võib, kütusefilter oleks ka siis tegelikult peaks gaasi andes hakkama puterdama vms, sõidu ajal pole mitte muhvigi ainult IDLE ajal. Filter umbes siis peaks fuel pressure vea sisse lööma ? Paagisisene pump ka undas kui arvutiga proovisin aga see ka kahtlane, peaks ta siis välja surema vms?
Ma loodan, et ehk saan mõne hea vastuse ja ehk kellegil midagi sellist olnud.
IvarV
Registreerunud 04.08.13
Auto: 3.0 TFSI
postitati 30.04.17 21:22 Tsiteeri
Kas tõmbleb 800-600 või 800-1000 pöörde vahel?
postitati 30.04.17 22:06 Tsiteeri
Pihustid uued originaal Bosch või mingisugune X "taastatud" variant?
Correction ei saa kuidagi olla sellel hetkel ühe koha peal, kui pööre üles-alla käib, ka kütusekogus mitte.
qqaabz
postitati 30.04.17 22:37 Tsiteeri
800-1000 vahel, uued originaal Bosch, 0445115078. Ühe kohapeal nad ei olnudki, lihtsalt täpselt ei mäleta aga minu mäletamist mõõda seal kahtlaseid kõikumisi ei tuvastanud, ka kütusekogus oli suhteliselt paigal. Võibolla ka sellepärast, et täna ei saanud ka seda nö räiget tõmblemist kätte ka mis eile.
qqaabz
postitati 02.05.17 12:37 Tsiteeri
Pole enam seda suurt tõmblemist tähendanud, et laseks üles-alla 200pööret, ei tea mis asi see sedasi tegi aga nüüd on järgi jäänud selline kerge 50pööret üles-alla, seda kõikumist on kerge vibrana tunda.
[PHP: 16.1% - SQL: 83.9%]
