Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Autogauge õlirõhu kell originaal anduriga.
Pealkiri: Autogauge õlirõhu kell originaal anduriga. (Vastuseid: 8 | Vaatamisi: 2170)
ahtisaar
Registreerunud 16.10.12
Auto: Audi q7 4.2tdi, Audi coupe 2.6
postitati 09.04.17 09:22 Tsiteeri
Kas on võimalik kasutada auto originaal õlirõhu andurit, et paigaldada autogauge seeria kell. Autoks audi V6 coupe ning olid olemas originaalis lisakellad keskkonsoolis aga tahaks need asendada teiste kelladega ja viia A-piilari külge. Kas piisab kui võtta originaal lisakellade otstest signaal?
Eints
Registreerunud 12.03.03
postitati 10.04.17 19:32 Tsiteeri
Kui mõlemad kellad näitavad sama maksimaalset tulemust, siis anduritel pole vahet. Kui üks kell on 5bar ja teine 7bar, siis võib tekkida mõõte viga.
ahtisaar
postitati 10.04.17 20:05 Tsiteeri
Aga kui asendada originaal andur kellaga kaasas olnud anduriga?
laurz
Registreerunud 30.12.05
Auto: b4TQ :D E39
postitati 11.04.17 04:32 Tsiteeri
Siis on ju komplekt ja töötab nii nagu peab.
ahtisaar
postitati 11.04.17 05:22 Tsiteeri
Algselt postitas: laurz
Komplekt olemas küll, kuid ei taha kahte erinevat andurit sinna külge. Et originaal on õlitule jaoks ning teine siis kella jaoks.
Kas siis piisab, kui vahetan vana anduri uue vastu ja kasutan auto enda juhtmeid? Või peab ikkagi uuele andurile eraldi kaabelduse tegema.
Eints
postitati 12.04.17 03:49 Tsiteeri
Järelturu andurile pead lisa massi vedama. Õlitule tarvis pead lisa anduri paigaldama. OE andur võtab massi mootorit ja on kahe süsteemne, annab signaali õlitulele ja kellale. Järelturu anduritel käib ühe klemmi alla mass ja teisest tuleb signaal kellale.
ahtisaar
postitati 28.04.17 20:28 Tsiteeri
Algselt postitas: Eints
OE andur on kahe süsteemne, annab signaali õlitulele ja kellale.
Seda ma tean, et ta on kahesüsteemne ning sellepärast uuringi. Ei tahaks sinna kahte eraldi andurit panna kui üks andur suudab kahte asja teha. Aga kas ei saa OEM kellale mineva juhtme otsa panna mitte OEM kella(autogauge oma näiteks)?
postitati 28.04.17 22:23 Tsiteeri
Algselt postitas: ahtisaar
Jah, aga jõuame ringiga tagasi algusesse:
ahtisaar
postitati 29.04.17 09:05 Tsiteeri
Selge. Sain piisava kinnituse.
Tänud vastajatele.
[PHP: 21.7% - SQL: 78.3%]
