Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 132kw 2.5v6 diisel generaator
Pealkiri: 132kw 2.5v6 diisel generaator (Vastuseid: 1 | Vaatamisi: 753)
spindle
Registreerunud 08.10.12
Auto: B4Q1.8T
postitati 10.11.16 15:47 Tsiteeri
Küsimus, kas eelpool nimetatud masina pealt 140A generaator sobiks AEB mootorile kinnituste ja rihmarataste ühel joonel olemise poole pealt?
postitati 10.11.16 21:01 Tsiteeri
1.9 tdi pealt 120a genekaga läks juba nii kitsaks, et kolde ja geneka korpuse vahele jäi ca 1mm ruumi. Kui 140a genekas sama suur mõõtmetelt, siis sobib.
Edit: kui pilte tahad, kui väheks ruumiga jääb, küsi kasutaja weiks käest. Ta b4 avandil 1.8 20v moto aeb sisselaske ja 120a genekaga. Temalt saad ka sobiva geneka tootekoodi kui vaja. :)
[PHP: 15.2% - SQL: 84.8%]
