Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mootori vahetus
Pealkiri: Mootori vahetus (Vastuseid: 7 | Vaatamisi: 1415)
tarvoseer
Registreerunud 03.02.12
Auto: Audi A6 Quattro 2.8 142kw 1998a
postitati 17.06.16 09:11 Tsiteeri
Mootori vahetus
Tere.
Selline asi, et plaanis on hakata audi a6 2.8 142 kw 98 a mootorit vahetama. Panen sama mootori peale aga kood on ack ja enda mootori kood on alf. Küsimus kas saan üldse peale panna või läheb ka teise koodiga aju ja juhtmestikku vaja?
Auto: 6x4x4
postitati 17.06.16 10:30 Tsiteeri
Üks on 2,8 ja teine 2,4, ehk siis mitte just päris sama. Vaata füüsilised erinevused plokil üle, kas teise mootori küljes on kõik füüsilised kinnitused ikka olemas igasugu pudimudile mootoriploki ümber.
tarvoseer
postitati 17.06.16 11:46 Tsiteeri
Teine on ka ikka 2.8 142 kw lihtsalt kood on teine.
Johnny
Registreerunud 23.03.07
Auto: Jeep GC
postitati 17.06.16 12:03 Tsiteeri
ALF on 2.4 mootor. MOOTORIKOODID.
Elektri-, remont ja hooldustööd+ custom tehnilised lahendused. LT Service OÜ
tarvoseer
postitati 17.06.16 21:12 Tsiteeri
Huvitav. Dokis on 2.8 ja koodiga hoopis 2.4
postitati 18.06.16 07:49 Tsiteeri
Algselt postitas: tarvoseer
Reaalne kood mootoril tasuks siis üle vaadata, kui selgust ei saa.
tarvoseer
postitati 18.06.16 08:23 Tsiteeri
Kus seda koodi leida?
postitati 18.06.16 08:54 Tsiteeri
Plokilt vöi kaanelt selle peaks leidma, kuid täpset asukohta ma ei tea pakkuda.
[PHP: 20.8% - SQL: 79.2%]
