Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - a6 c4 2,5 tdi ael 103kw kõrgsurve pumba remont.
Pealkiri: a6 c4 2,5 tdi ael 103kw kõrgsurve pumba remont. (Vastuseid: 0 | Vaatamisi: 1474)
vamps
Registreerunud 23.01.14
Auto: Audi a6 c4 2,5 tdi quattro
postitati 26.01.16 17:57 Tsiteeri
Tere. Oskab keegi öelda kas tartus või kusagil lõuna eestis keegi remondiks nimetatud autol kõrgsurve pumpa ja suudaks selle ka pärast paika seada, süüted ja muu sinna juurde kuuluva. Nimelt autol selline probleem,et -10 või külmem käivitub pika käiamise peale. -10 ja soojem läheb nö.poolest pöördest. Arvutiga kontrollides selgus,et kõrgsurve pumba sees mingisugune solenoid annab kogu aeg vea teadet,kustutad ära ja sekundi pärast on kohe tagasi. Ka näitas arvuti,et süütenurga mingi arvnäitaja on 125 kui normaalne oleks 45-65. Mida iganes see siis tähendab. Tuleb välja,et nim.solenoid regullib külmkäivitust. Selle vahetus ongi pump maha ja pulkadeks-ei tea sedagi kas üldse on see solenoid vahetatav või on ainult koos pumbaga. Oskab äkki keegi siis infot anda? Võib pakkuda ka remontijaid kaugemalt. Tänud.
[PHP: 9.2% - SQL: 90.8%]
