Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - R peal saab sõita aga D peal mitte.
Pealkiri: R peal saab sõita aga D peal mitte. (Vastuseid: 22 | Vaatamisi: 1996)
Iandre
Registreerunud 18.09.15
Auto: Audi A6
postitati 17.01.16 19:42 Tsiteeri
Tervist.
Auto: Audi a6 avant quattro 2.5tdi 132kw 2000a AUTOMAAT.
Mure siis järgmine, et läksin täna sõitma ja esisillas oli suhteliselt suur kolks.
Sõitsin mööda maanteed ja käis pauk ära ja midagi lendas minema... Jäin seisma ja mootoriõli jooksis välja..
(võibolla lõi mingi asja lahti ja lendas vastu õlivanni vms)
Kõige suurem mure selle asja juures on, et tagurpidi saan sõita, aga D peale panna siis korraks laseb edasi minna ja siis jääb lihtsalt kinni..
Milles võib probleem olla?
Kiiruga kirjutasin, kui keegi millestki aru ei saanud siis PM või siia alla.
Ettetänades.
pontu
Registreerunud 22.03.06
Auto: Audi A6 2,8Q C5 , on ajalugu.
postitati 17.01.16 19:48 Tsiteeri
Kuhu kavatsed jõuda ilma mootori õlita?
Iandre
Auto: Audi A6
postitati 17.01.16 19:51 Tsiteeri
Auto on juba garaazis :)
Iandre
Auto: Audi A6
postitati 18.01.16 15:00 Tsiteeri
Siiski on abi vaja..
Mis võib katki/läbi olla?
Hegol
Registreerunud 20.09.06
Auto: Audi 80 B2q & Audi 80 B3q 16v & Audi A4 Avant B9q & Audi Q4 e-tron q
postitati 18.01.16 15:33 Tsiteeri
Mees, sul on auto katki ju, kui mootorist õli välja jooksis. Vii pädevate remondimeeste kätte, kui ise aru ei saa.
Ma muidu ei erutu selliste teemade peale, aga koheselt meenus: Noored tehnikud
Ehk siis loo moraal peaks olema see, et läbi interneti aju ei saa remontida.
Iandre
Auto: Audi A6
postitati 18.01.16 15:39 Tsiteeri
Põhi küsimus on siiski see:
varemax
Registreerunud 27.03.11
Auto: Audi a4 b8 2,0 tdi 2008
postitati 18.01.16 18:44 Tsiteeri
Kui väliselt muid vigastusi/takistusi ei märka siis polegi muud kui kast otsas.
ragenor
Registreerunud 21.05.14
Auto: A8L 4.2, B4 2.0E
postitati 18.01.16 18:56 Tsiteeri
Kõlab küll lollilt, aga kindel et mootorist õli välja tuli. Äkki lasid kasti hoopis pauguga puru ja sealt tuli õli. Mis asi saab esisillast lennata nii, et karter puru. Oled käinud auto all reaalselt ja vaadanud? Kui jah siis kirjelda olukorda täpsemalt.
Iandre
Auto: Audi A6
postitati 18.01.16 19:03 Tsiteeri
Enne sõitma hakkamist kontrollisin õli taset ja oli normis, pärast pauku 30min hiljem kontrollisin õli tase oli 0.
Alt vaadates oli ainult paremalt poolt ülevalt näha kuidas õli oli alla jooksnud, aga kuidas see mõjutab käigukasti?
Kui kast on "N"i peal ja pidurdada siis tõmbab kõrvalistuja poolne ratas blokki ja 2sekundit hiljem võib sõit edasi minna.
vibro
Registreerunud 01.10.11
postitati 18.01.16 19:17 Tsiteeri
Kas mootoris nüüd õli sees kui üritad sõita?
Ja võibolla selle kolksu põhustaja midagi sellist mis kiilub ratta kinni ja sellepärast ei liigu edasi et ei jaksa lihtsalt.
Iandre
Auto: Audi A6
postitati 18.01.16 19:26 Tsiteeri
Enam tegelt erilist vahetpole.. Homme läheb auto tõstuki peale ja saab asjast paremini sotti.
Võin pärast kirjutada siia mis viga oli :)
ragenor
postitati 18.01.16 19:32 Tsiteeri
Algselt postitas: Iandre
Tore oleks. Abiks järgmistele.
sir-mac
Registreerunud 26.06.03
Auto: S6 4,2 Avant
postitati 18.01.16 19:33 Tsiteeri
Väga õige otsus!
varemax
postitati 18.01.16 19:34 Tsiteeri
Väga segane jutt on kokkutulnud.
Mootor ise käivitub? tagurpidi sõidab ja edasi ei sõida? Kus kohast täpselt tuli välja õli? ja kõige tähtsam miks se välja tuli?
Hegol
postitati 19.01.16 06:32 Tsiteeri
Kuna sa kirjutad nii palju vastuolulist juttu, siis keegi ei saagi sind aidata. Inimesed on erinevad, aga kui minu autol jookseks kuskilt õli välja, siis viimane asi, mis ma teeksin enne kui õli lahkumise põhjused selged, käivitaks autot ja veel prooviks sellega sõita. Kui ise asja ei jaga ja pole kohta, kus autot üle vaadata, laseks auto viia remondikohta, kus see üle vaadatakse.
Ja jätkuvalt olen ma seisukohal, et autosid (tegelikult ükskõik mis seadmeid) ei remondita interneti teel. Keegi ei ole selgeltnägija, et täpselt näha, mis sul seal juhtus ja kuidas seda parandada.
Janryk
suletud konto
Registreerunud 31.08.15
postitati 19.01.16 09:24 Tsiteeri
Mul ka sama probleem, sidur katki. Tagurpidi sõidab sellepärast et tagumisele käigule eraldi sidur.
Endal muidugi multitronic..
Crp
Registreerunud 22.04.10
Auto: Audi C4 2.5TDI Quattro + Audi 90 Type85 + Hunnik teisi kolusi
postitati 19.01.16 10:45 Tsiteeri
Tervitused. Mul sama mure, R käik on ainukene mis rakendub. Teised käigud ei rakendu, ntks D-peale minnes ei ole sellist tunnetki, et prooviks käiku lülitada. Asendeid kang tunneb, käigukastiajus vigu ei ole.
Audi A6 C5 quattro 2.7BIT - liigub ainult tagurpidi.
Kes mis diagnoosi paneb?
Müüa erinevaid audide varuosi, võite pakkuda enda avariilist ja rikkega autot. Järvamaal sõiduautode salongi tekstiilipesu ja rehvivahetus - 58367192
ragenor
postitati 19.01.16 11:36 Tsiteeri
Siin pole mõtet lampi pakkudagi midagi.
Mina võtaksin esimese asjana kõne näiteks Hõbenoolde ja kurdaks sinna. Sealt saaks ka mingid reaalsed variandid teada.
Ei maksa see helistamine ju erilist midagi ja vastus kiirelt olemas.
Iandre
Auto: Audi A6
postitati 19.01.16 14:29 Tsiteeri
Auto korras. Sisemine pooltelg oli lahti lendanud. Nüüd saab D peal sõita :)
Kast oli korras.
zaks
Registreerunud 20.03.06
Auto: c7.5 Bitdi
postitati 19.01.16 14:49 Tsiteeri
Kast oli korras.
Nüüd sõidad ilma mootoriõlita ringi siis või? :D
Siuke kapsas ja pudru,et anna olla .
Et reaalselt toppisite pooltelje lihtsalt tagasi ja annad autoga hagu edasi või?
Põhjused ikka ka likvideerisite ?
Käigukastiõli tase?
mtaudi
Registreerunud 26.02.07
postitati 19.01.16 17:53 Tsiteeri
Minu jaoks kergelt müstika see lause. Kas ennem igat sõitu kontrollid õlitaset? Kas juba ennem ka lekkis, et kontrollid?
varemax
postitati 19.01.16 18:22 Tsiteeri
:D Ma päris ausalt imestan kuidas varem pihta eisaanud,et midagi kohe kohe laiali lendab. Okei lendas laiali,lõhkus karteri ja õli jooksis välja. Nüüd ma küsiks,et mismoodi kallasid uuesti õli sisse ja õli seisab mootoris?. Ilmselt vahetati karter aga kuidas jäi märkamatuks tolknev pooltelg;).
postitati 19.01.16 21:43 Tsiteeri
Öösel juhtus et D peal ei taha auto liikuda? :D
https://www.facebook.com/keeptheheat/videos/10153550810792069/
Aga tore kui auto korras, muretud kulgemist taas!
[PHP: 20.8% - SQL: 79.2%]
