Pealkiri: Turbo seadistamine (Vastuseid: 2 | Vaatamisi: 2170)
drikk3000
Registreerunud 08.01.14
postitati 17.01.16 10:38 Tsiteeri
Turbo seadistamine
Tere
Plaanis vahetada autol Turbo (UUS) .Turbo vahetusega seoses tuleks ka juhtmoodul seadistada .Kas leidub tartus sellise töö tegijat peale Margiesinduse ?
Audi A8 d3 3,0 tdi
teet82
Registreerunud 17.11.13
postitati 17.01.16 15:48 Tsiteeri
Arvatavasti ainut esindus seda teha saabki, sest see eeldab spetsiaalset testrit, mis ühendatakse otse turbo külge. Olen huvi pärast neid juhendeid vaadanud ElsaWin-is, sest on küsitud selle töö kohta, tundub olevat parajalt keeruline pusimine.
txxxl
Registreerunud 22.11.11
Auto: Audi
postitati 17.01.16 18:56 Tsiteeri
Tere, keegi seda õpetust on proovinud.
033 Basic setting: Turbocharger
1) Coolant temperature at least 80 °C
2) Switch off ignition briefly, then start engine
3) Start basic setting
4) First press brake pedal, then accelerator pedal
Both pedals must be pressed during basic setting.
If they are not, the basic setting is aborted.
5) Wait for the engine speed rise to approx. 1000 rpm
KNote:
The turbocharger is now activated at intervals at different
duty cycles.
Specifications at "closed":
Engine speed: approx. 1000 rpm
Activation: closed
Charge pressure: 960 ... 1160 mbar
Duty cycle: 80 %
Specifications at "open":
Activation: open
Charge pressure: 920 ... 1060 mbar
Duty cycle: 20 %
Charge pressure difference between "closed/open": 50 ... 135 mbar OK is OK
[PHP: 8.1% - SQL: 91.9%]
