Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 1.9TDi 66kw lagiseb, jõud kadunud
Pealkiri: 1.9TDi 66kw lagiseb, jõud kadunud (Vastuseid: 0 | Vaatamisi: 1405)
taurtz
Registreerunud 11.06.10
Auto: Audi A6 2.8 Quattro
postitati 30.12.15 18:01 Tsiteeri
Tere.
Tekkis selline probleem, et sõidu pealt kadus jõud ära ja mootor hakkas lagisema, nagu süüde oleks liiga varajane.
Koha peal paarutades kadus viga ära ja paarkümmend kilomeetrit oli kõik korras, kuid siis tuli viga püsivalt tagasi.
Juhtpihusti takisust mõõtsin ka, see oli kuskil 110-120 oomi. Juhtpihusti pistiku lahti ühendamisel jäävad sümptomid samaks.
Kõrgsurve pumba või pumbakaane liigutamisel ei muutu ka suurt midagi.
Milles võib asi olla?
[PHP: 9.1% - SQL: 90.9%]
