Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi 80Q 2,0 83kw->2.0 103kw mootori swapiga küsimus
Pealkiri: audi 80Q 2,0 83kw->2.0 103kw mootori swapiga küsimus (Vastuseid: 3 | Vaatamisi: 982)
simo88
Registreerunud 15.12.10
Auto: audi 80 b3 101 kw ja a4 1.8q, VW G3 VR6
postitati 12.12.15 14:29 Tsiteeri
Tere, sõbral tekkis huvi oma audi 80 b3 quattrol mootor ära vahetada. Momendil on autol 2.0 83kw mootor peal ja tahaks asemele panna 2,0 103kw mootori. Aga kas 2.0 103kw mootor istu täpselt vana k.kasti külge ei tea. Soovis teada, et kas midagi vaja ümber ka teha või istub kõik 1:1. Kui keegi oskab täpselt öelda oleks tore. Enda teda peks kõik 1:1 olema, aga palus asja uurida, et kõik oleks 100% kindel.
Ette tänades
Simo
pampkuri
Registreerunud 08.03.04
postitati 12.12.15 21:18 Tsiteeri
Miks seda mootori vahetust vaja üldse on, et jõudu juurde saada?
Rain573
Registreerunud 17.09.05
postitati 12.12.15 21:30 Tsiteeri
Sobib 1:1. Isegi juhtmestik peaks enamvähem sobima :D. Vb väiksed ümberehitused vaja teha. Aga jah, suht mõtetu üritus :D See 2,0 doss on selline suht lahja teema ikka, pööretepeal on mingit jõudu aga väänet on suht vähe ja käiguvahetusega kukuvad pöörded nii palju et jõud kaob ära jne. jne... Kui siit edasi mingi turbokas aretada siis võibolla veel aga see ka suht küsitav värk...kas mingit mahlapaki on mõtekas turbotada? Pigem juba mingi rajum mootor ja kui lahjaks jääb siis turbod ja jutud :D...sest kui ehitada siis naguinii rulli läheb kõvasti ;)
simo88
postitati 12.12.15 21:43 Tsiteeri
No sõber uurib seda asja kuna tahab talvel jääle minna kui ilm lubab. Aga praegune mootor vajab liigsed investeerimist, et ilusti käima saada ja 103kw mootorit pakuti soodsalt. Plaan pole ehitada mingit püssi vaid autot millega saaks natuke lõbutseda ilma suurte kulude ja ümberehitustega.
Aga tänan info eest:)
[PHP: 16.1% - SQL: 83.9%]
