Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 B3 1.8S 66kw ei käivitu.
Pealkiri: Audi 80 B3 1.8S 66kw ei käivitu. (Vastuseid: 8 | Vaatamisi: 1299)
Kevin1999
Registreerunud 21.10.15
postitati 03.12.15 17:02 Tsiteeri
Mure selles,et auto ei käivitu enam.Kui käiata ss vahepeal sumpsist paugub,aga käima ei lähe.
Oskab keegi öelda mis viga võib olla??
postitati 03.12.15 17:18 Tsiteeri
Algselt postitas: Kevin1999
Kas eelnevalt miskit toimingut ka sooritatud vöi lihtsalt otsustas, et enam koostööd ei tee?
Kevin1999
postitati 03.12.15 20:43 Tsiteeri
Sai vahetatud plokikaane tihend ära ja peale seda.Isegi Quick Startiga ei lähe
postitati 03.12.15 20:47 Tsiteeri
Rihma märgid paigas? Süüde ka paigas?
Kevin1999
postitati 03.12.15 21:40 Tsiteeri
Märgid sai pandud paika.Aga süüdet pole muutnud
Reims86
Registreerunud 12.08.13
Auto: Audi A6 171kw 3,0TDI Quattro / Audi A4 110kw 2,5TDI / Opel Corsa E 2015a
postitati 04.12.15 05:29 Tsiteeri
Eeldusel, et küünlajuhtmed olid samuti maas seoses plokikaane eemaldusega, siis olid need maas. Seega küsimus, et kas süütejärjekord on samuti paigas?
Kevin1999
postitati 04.12.15 09:23 Tsiteeri
Küünlajuhtmetele sai sildid peale pandud numbriga nii et need korras
yanekk
postitati 04.12.15 09:57 Tsiteeri
Selle asemel et siin vaielda, et kõik on õige ja ikka käima ei saa, hakka oma näputööd uuesti üle vaatama.
Kui enne töötas ja nüüd mitte, siis viga on selles toimingus mida tehti.
Best ET 12.08 :)
Undercover
Registreerunud 08.07.14
postitati 10.12.15 20:47 Tsiteeri
Kui paugub, siis süüde ikka vale. Vaata veelkord üle.
http://www.upload.ee/image/4465959/margid.JPG
Omal kunagi oli juhus, kus rihma vahetades läks "AUX" ratas (ehk siis jagaja oma) hammas või paar mööda. Vaatasin küll, et nuka ja väntvõlli märgid paigas aga selle peale kohe ei tulnudki, et seda kolmandat ka kontrollida. Õnneks ei läinud palju mööda, sain jagajat keerates asja korda. Võid ka igaksjuhuks jagajat keerata ning ei tee paha ka 1-3-4-2 kontrollimine ;)
[PHP: 19.6% - SQL: 80.4%]
