Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleem kesklukuga a4 b7 2005a avant
Pealkiri: Probleem kesklukuga a4 b7 2005a avant (Vastuseid: 10 | Vaatamisi: 1411)
aadva
Registreerunud 09.03.12
postitati 03.12.15 08:48 Tsiteeri
Tere.
probleem siis selline et puldist ei lähe uksed lukku. Võtmega keerates läheb. Puldil patarei vahetatud jne. Ehk oskab keegi öelda milles võib asi olla ? Ehk kellegil olnud sama mure vms.
Gunnark
Registreerunud 27.10.09
postitati 03.12.15 08:58 Tsiteeri
Algselt postitas: aadva
Tere.
Puldist avab?
aadva
postitati 03.12.15 08:59 Tsiteeri
ei ava. kui pulti vajutan siis põleb vaid see punane tuli puldil. patarei vahetatud.
aixx
Registreerunud 21.03.05
postitati 03.12.15 09:00 Tsiteeri
Tutvusta pult autole ära.
http://www.audizine.com/forum/showthread.php/428047-How-to-program-your-Audi-flip-key-fob
Gunnark
postitati 03.12.15 09:06 Tsiteeri
Tee see sünkroon läbi, võib abiks olla.
Lühidalt, võtmega uks lahti, süüde sisse, vajuta puldil uksed lukku või lahti hoia pisut aega. Aknad liiguvad sul ühe vajutusega alla, või peab hoidma?
Siin ka hunnik erinevaid sünkroonimist:
Steps to reprogram keys to a car they are already linked to:
1. Press and hold the unlock key on a remote
2. Insert key in ignition and turn to on (while still holding unlock)
3. Hold unlock while in the on position for 2 seconds
4. Turn key to off, remove from ignition and release button.
Do this for each remote. Relink to seat positions (press and hold mem position #, then unlock button for 2 seconds and release both) and done.
To program new remotes on a car never linked to previously:
1. Take a key (valet key works best, put it into the ignition and turn the key to the "on" position, so the dashboard lights come on.
2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
3. Exit the car and close the door.
4. With a second key, physically lock the doors by turning the key clockwise (don't use a remote).
5. Take the first remote to be programmed, press the unlock button. The lights will flash once.
6. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
***If you have only one key skip to step 16. Otherwise continue to step 7.***
7. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
8. Press the unlock button two times with a one second interval in between, the lights will flash with each button press for a total of two flashes.
9. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed.
***If you have three keys proceed to step 10. Otherwise skip to step 16.***
10. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
11. Press the unlock button three times with a one second interval in between, the lights will flash with each button press for a total of three flashes.
12. Wait 10 seconds and press the unlock button. The doors should unlock. The third transmitter is now programmed.
***If you have four keys proceed to step 13. Otherwise skip to step 16.***
13. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
14. Press the unlock button four times with a one second interval in between, the lights will flash with each button press for a total of four flashes.
15. Wait 10 seconds and press the unlock button. The doors should unlock. The fourth transmitter is now programmed.
16. Remove the key from the ignition.
Make sure that to test the newly program remotes, the original key is removed from the ignition since this exits the programming process. Someone might be a bit frustrated trying to test it with it still in 'program' mode.
I had some diffuculty accessing the programming mode. If it doesnt work then take the key out of the ignition and start over. Rinse lather repeat. It will go eventually.
If you are still having problems after trying it more times than you can count, check the key is right one for year of car or that the key and battery are good.
Ups:topelt post nö:)
aadva
postitati 03.12.15 10:30 Tsiteeri
pult
pean proovima. tänud seniks vastajatele:)
aadva
postitati 03.12.15 10:32 Tsiteeri
aknad
mul ei liigu aknad üldse puldist kinni ega lahti nii nagu sakslastel tavaliselt. hoia peal kaua tahad aga ei midagi.
meelo
Registreerunud 07.01.06
postitati 03.12.15 10:51 Tsiteeri
Järelikult on comfort funkts aktiveerimata moodulis.
aadva
postitati 03.12.15 11:06 Tsiteeri
ehk siis? kuidas seda teha saab?
meelo
postitati 03.12.15 12:43 Tsiteeri
Tuleb pädeval tehnikul vcds järgi ühendada autole ja see funktsioon aktiveerida.
Gunnark
postitati 03.12.15 12:45 Tsiteeri
Kaabliga. Aga akende all mõtlesin, kas salongist praegu vajutades jookseb aken üles/alla ilma nuppu hoidmata vb see sync ka paigast ära ja oled vb akut näppinud.
[PHP: 46.7% - SQL: 53.3%]
