Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Xenonid on uimased
Pealkiri: Xenonid on uimased (Vastuseid: 3 | Vaatamisi: 1045)
kubias
Registreerunud 26.07.10
Auto: audi a6 1,8
postitati 02.12.15 17:35 Tsiteeri
Xenonid on uimased
Tere : Xenonid on uimased kui lülitad lähi tulede pealt kaug tuledele läheb natuke aega et normaalselt näitama hakkavad, kas plokid väsinud või pirnid vanad ? autoks a8 96 a Xenonid ise pandud, mitte mina.Ostsin äsja.
yanekk
postitati 02.12.15 17:37 Tsiteeri
Algselt postitas: kubias
On sul üldse aimu selle pirni tööst?
Hiinakas ei peagi kohe põlema hakkama.
Best ET 12.08 :)
kubias
Auto: audi a6 1,8
postitati 02.12.15 17:42 Tsiteeri
Pole aimugi mis seal sees on, kui hiinakas siis tuleb välja vahetada sai nii aru .
Tarmo_j
Registreerunud 12.05.13
Auto: Audi A6 C6 3,0tdi 2004a
postitati 02.12.15 19:50 Tsiteeri
Kuna xenon tahab soojenemist, ja kui ei ole tegemist Bi-xenoniga siis esimesed lõlitused ongi uimased.
Kui pirn on soojaks läinud siis peaks suht kohe lülituma.
Kui on Bi-xenon siis on üks sama pirn lihtsalt mingi katik liigub, siis peaks olema ümberlülitus kiire.
[PHP: 42.3% - SQL: 57.7%]
