Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Tiptronicu käsitsi käiguvahetus ei toimi alla vahetades
Pealkiri: Tiptronicu käsitsi käiguvahetus ei toimi alla vahetades (Vastuseid: 3 | Vaatamisi: 1147)
mosse1
Registreerunud 06.01.08
postitati 01.12.15 19:15 Tsiteeri
Auto A6 c5 98a 110 kw diisel. Selline probleem, et tiptronicu peale lülitades käike ülesse vahetab aga alla ei vaheta. 5hp 19 .
Auto: 5x4x4
postitati 02.12.15 10:35 Tsiteeri
Juhtmekimp või pistik (vaevalt) või juhtplaat käigukangi korpuses vaja üle vaadata/korrastada. Üldjuhul viga füüsiline ja näeb seda siis kui lahti võtta. Eks tal ole vanust kah juba omajagu :).
mosse1
postitati 02.12.15 19:47 Tsiteeri
Küsiks ka seda et kuidas eemaldada seda käigukangi keskkonsoolist. Nimelt selline lugu et lagunes seal midagi ära ja enam ei pea pidurit vajutama kui kangi liigutada. Nupp kangi küljes hõljub lihtsalt edasi tagasi. Nupp ei toimi. Bmw oli seal tross aga c5 pole lihtsalt lammutand ja kogemus puudub.
iguaan
Registreerunud 10.02.13
Auto: B7 A4 Avant 2.0T quattro 147kw '05
postitati 03.12.15 09:42 Tsiteeri
https://youtu.be/wxPiFT7mRKE
[PHP: 40.4% - SQL: 59.6%]
