Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 B4 mootor puterdab
Pealkiri: Audi 80 B4 mootor puterdab (Vastuseid: 4 | Vaatamisi: 1125)
Harakas
Registreerunud 20.11.15
Auto: Audi 80 B4 2.0E
postitati 20.11.15 15:42 Tsiteeri
Tere
Mureks siis selline, et Audi 80 B4 1992a. 2.0e 85kw (manuaal, bensiin) mootor väristab tugevalt...pole jõudu edasi minna.
Sai hiljuti vahetatud rootor, jagajakaan, küünlajuhtmed ning ka küünlad ja mootor töötas ilusti ning minek ja jõud kõik olemas. Kuid see lõbu kestis vaid u. 2nädalat ja nüüd mootor väriseb nii tühikäigul kui ka kiirendades (töötab nagu traktor, ka hääle poolest). Käima läheb ilusti ja pöörded on stabiilsed. Oskab keegi mingit nõu anda?
Homme saan lisada ka video.
ülks
Registreerunud 04.12.04
postitati 20.11.15 16:02 Tsiteeri
Algselt postitas: Harakas
Tere
Rihmamärgid paigas? Kõik silindrid töötavad?
www.teemetünni.ee
Harakas
postitati 20.11.15 16:07 Tsiteeri
Rihmamärgid peaksid olema paigas, kuna vahepeale töötas ilusti ning rihma ega muud nodi sealt maha pole kiskunud vä. siis rootor ja eelpoolmainitud.
Silindrite osas jään vastuse võlgu.
Harakas
postitati 22.11.15 15:28 Tsiteeri
Nii... mõtlesin, et kontrollin küünlad ka igaksjuhuks üle ning avastasin, et 1.silindri küünal kõvasti tahmasem kui ülejäänud kolm. Millest see tingitud on?
ülks
postitati 22.11.15 15:44 Tsiteeri
See silinder ei käi korralikult. Lihtsamad vead: küünal või küünlajuhe katki, jagajakaan. Kui need kõik korras, siis tuleks edasi vaadata. Kui teised küünlad olid ilusad pruunid, siis tegelegi selle esimese silidriga, sest tõenäoliselt viga seal.
www.teemetünni.ee
[PHP: 22.2% - SQL: 77.8%]
