Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.5 85kw hakkas tossama.
Pealkiri: 2.5 85kw hakkas tossama. (Vastuseid: 4 | Vaatamisi: 1189)
drtarmo
Registreerunud 23.11.14
postitati 06.11.15 18:29 Tsiteeri
Tere, kohapeal tossab päris palju, just sinist. Sõittes tunds, et ei tossa, kuid kui auto sõitis järel tuledega oli näha, et ka koormuse juures tossab, kuid vähem.
Leidsin lõdviku, kus oli mõra. Märgistasin kollaseks. Pilt:
http://www.upload.ee/image/5315131/12202214_969794019755187_1611419346_n.jpg
asendasin selle alternatiiv lõdvikuga. Seis jäi suhteliselt samaks. Seal peaks siis surve olema ? Kas see üldse mõjutab tossamist?
Kas selle kollase toru sisse vaadates peab olema kõik kuiv? Mul nagu kondentsi tilgad, õlimoodustis...
Või pihusti ots või otsad läksid läbi. Ei piserda nii nagu peab, vaid tilgub, niriseb.
Või õhupuhasti süüdi? Ennem oli jubekinni, uut ei pannud, aga tegin puhtaks kõik. Ja suitsema hakkas võib öelda päevapealt.
drtarmo
postitati 08.11.15 20:15 Tsiteeri
Küttesegu viga ei saa olla.
Mis värvi toss näitab õhupuhast ummistumist?
ülks
Registreerunud 04.12.04
postitati 08.11.15 20:26 Tsiteeri
Algselt postitas: drtarmo
Pigem nagu must.
Sinine üldjuhul viitab siiski õli põlemisele.
www.teemetünni.ee
postitati 08.11.15 20:39 Tsiteeri
Mis see kollase ja vana musta ühendus on sul survekindel?
drtarmo
postitati 08.11.15 21:18 Tsiteeri
See märgistamise pärast, see lõdvik asendatud. Probleem jäi alles.
Oletame, et see lõdvik, ei pea, mis siis tunnused on? Ehk klambrite kohapealt saab lisaõhku? Vahetan asju ükshaaval, siis saan aru mis muudab, see lõdviku vahetus ei muutnud midagi.
Äsja vahetatud plokikaane, kambrikaane tihend. Peale remonti sõitis ilma muredetta. Siis oli ka see märgistatud lõdvik mõraga. Võib öelda, et päevapealt hakkas tossama.
[PHP: 28.9% - SQL: 71.1%]
