Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 80 Avant luugituled
Pealkiri: 80 Avant luugituled (Vastuseid: 1 | Vaatamisi: 726)
kristo57
Registreerunud 05.03.14
Auto: Audi A4 B7 1.9 85kw
postitati 06.11.15 13:12 Tsiteeri
80 Avant luugituled
Mure järgmine, et tagaluugi tuled ja kojamees ei tööta. Algselt arvasin, et nagu ikka, juhtmed katki väändunud luuki minemise koha pealt ja sai sealt lahti võetud ning need üle vaadatud.
Seejärel proovides tuled põlesid ja tundus probleem kadunud olevat. Hakkasin juba vaikselt asju kokku pakkima ja toimetasin auto ümber kui avastasin, et jälle ei põle. Mõtlesin ja uurisin ja katsetasin kuni lõpuks jõudsin järeldusele, et mis tingimused peavad olema täidetud selleks, et luugielektroonika töötaks:
- Tagaluuk avatud, kas või sentimeeter, peaasi, et kinni ei ole
- Vähemalt üks kolmest reisijauksest avatud, vahet ei ole milline ja samamoodi, vahet ei ole kui palju avatud.
- Juhiukse kinni/lahti olemine ei mõjuta (võimalik, et seal mingi probleem anduriga, tuleb ette olukordi, et uksed on kinni, aga salongivalgustus põleb asendis "uks avatud" ja juhiuks annab märku, et on lahti).
Kohe kui luuk või uks kinni panna, kustuvad tuled ära. Selhetkel läbib luugi voolujuhet ~0.5V 12V asemel. Ja sedasi välja kuni rooli alla ja nii kaugele kui vaatasin. Väga palju polnud aega enam lammutama hakata, et täitsa üles leida, kust see jama pihta hakkab.
Kellelgi ideid, mida vaadata?
postitati 06.11.15 13:38 Tsiteeri
Kõlab nagu oleks mingisugune massi probleem, et siis kui salongi ja pagasi ruumi tuled põlevad, siis saab sealt kaudu kuidagi moodi massi vms.
Alustuseks prooviks võtta salongi ja pagasi ruumi valgustus lampidest pirnid välja ja vaata kas siis luugituled toimivad (vähemalt üks uks ja luuk avatud asendis). Siis ehk saad hakata edasi järge ajama.
[PHP: 47.1% - SQL: 52.9%]
