Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - madalatel pööretel ei puhu kuuma
Registreerunud 31.10.15
postitati 31.10.15 11:48
Tere, autoks A6 Allroad, 3,0 tdi. Mure selline, et tühikäigul ja madalatel pööretel ei puhu salongi kuuma, mootori temp on 90+ kraadi. Hoidsin
tühikäigul kuskil 2000 pöörde peal, ning siis kõik toimib, puhub tulist õhku.
Kas oleks soovitusi, kuidas probleemi lahendada?
Lgp,
Paul
yanekk
Registreerunud 12.08.13
Auto: Audi A6 171kw 3,0TDI Quattro / Audi A4 110kw 2,5TDI / Opel Corsa E 2015a
postitati 31.10.15 12:29
Kas paisupaagis jahutusvedelikku piisavalt?
sir-mac
Registreerunud 26.06.03
Auto: S6 4,2 Avant
postitati 31.10.15 12:36
Las tuksub tühikäigul kuni sooja enam ei puhu ning katsu siis soojendusradika sisend- ja väljundlõdvikut. Peavad olema suhteliselt sama soojad. Kui ei
ole võib viga olla ummistuvas (-nud) radikas.
Veel võib selline asi toimuda siis, kui jahutust on vähe, aga sellest peaks andma märku paisupaagi tasemeandur.
Mingi võimalus on ka surema hakkav veepump, aga ise seda ei usu.
[PHP: 15.7% - SQL: 84.3%]
