Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 vabal käigul sureb maha
Pealkiri: Audi 80 vabal käigul sureb maha (Vastuseid: 4 | Vaatamisi: 1199)
AndresE
Registreerunud 27.03.14
Auto: Audi A4 B7
postitati 03.10.15 06:05 Tsiteeri
tervist!
Audi 80 b3 1.8 66kw '87
Mure järgmine, et autot tuleb pikalt käiata, ning et lõpuks välja ei sureks, tuleb gaasiga mängida. Tühikäigul hakkavad pöörded langema, langevad ikka võimalikult madalale, sinna 200-300ni ja lõpuks sureb üldse välja.
Infoks veel niipalju, et tegemist on sissepritsega, mootor olevat ära vahetatud. Oskab keegi midagi välja pakkuda?
andres.
AndresE
Auto: Audi A4 B7
postitati 03.10.15 16:05 Tsiteeri
Netist uurides siiamaani pakutud, et võimalikud variandid tühikäigumootor, kütusesurveregulaator või siis lihtsalt mõni voolik umbes omadega. Pumbas ometi olla ei saa asi, kuna gaasi andes võtab pöörded üles ju küll ning vastasel juhul sureks mootor kohe välja. Eksin ?
moora772
Registreerunud 14.05.08
Auto: Audi 90Q 2.3 100kw 1990
postitati 06.10.15 07:42 Tsiteeri
Vaakum, kummimuhvil õhufiltri ja drosselklapi vahel kontrollida pragusid.
Pritsepea valesti reguleeritud, külmkäivitus üle vaadata.
Kütusesurve kontrollida, kas kütusefilter vahetatud?
Need on esmased asjad.
AndresE
Auto: Audi A4 B7
postitati 25.10.15 19:18 Tsiteeri
Eelmine jama sai lahendatud pritsepea vahetusega. Nüüd aga sama jama jälle, ainult et seekord ei jää isegi mitte puterdama, vaid sureb vabakäigul kohe välja ja pöördesse läheb pika ketramise peale. Küttefilter on uus ja peale proovitud teist kütusesurveregulaatorit, kuid probleem ei kao. Vaakumvoolikud kontrollitud, pragusid ega lekkeid visuaalselt ei olnud.
Ideid?
kki
Registreerunud 19.02.11
Auto: Audi 90; IZ 412; Honda CBR
postitati 26.10.15 05:49 Tsiteeri
Kas tühikäiguklappi ka kontrollisid? Mul on see üks kord ette tulnud. Cleaneriga puhtaks, natuke õli vahele ning toimib siiani.
[PHP: 27.3% - SQL: 72.7%]
