Pealkiri: Puldi patarei (Vastuseid: 7 | Vaatamisi: 3995)
TK90
Registreerunud 15.09.15
postitati 15.09.15 19:03 Tsiteeri
Puldi patarei
Kuidas Audi A6 Avant C5 puldil patareid vahetada või kas saab seda lasta kuskil teha? Pult reageerib ainult üsna lähedal autole ja kindla nurga alt, seetõttu arvangi, et ehk on vaja patarei vahetada.
Tänan!
Kev95
Registreerunud 27.01.11
Auto: A6 C6
postitati 15.09.15 19:19 Tsiteeri
https://www.youtube.com/watch?v=X_iLT7hqLuo
Palun.
TK90
postitati 15.09.15 19:35 Tsiteeri
Aitäh!
See patarei vahetamine ise on lihtne, aga kas seal seda ohtu pole, et pärast kesklukustus ei reageeri enam? Osades postitustes oli midagi kirjas, et 1 minuti jooksul tuli kindlad liigutused ära teha, et pult asju ära ei unustaks.
Ma olen üsna roheline sellel alal, sellepärast küsingi siin süvitsi järele.
Kev95
Auto: A6 C6
postitati 15.09.15 19:44 Tsiteeri
Autodata
If key buttons operated repeatedly while vehicle out of range or batteries replaced, and system becomes inoperative, proceed as follows:
Depress lock or unlock button.
Manually lock and unlock driver's door within 30 seconds.
System should now lock or unlock vehicle.
If not, carry out programming procedure.
Switch ignition ON. Use key not fitted with remote control.
Manually lock driver's door using key.
Complete the following within 30 seconds:
Within 5 seconds press unlock button on first key once (programs memory position 1).
Indicators flash once to indicate signal received.
Wait 5 seconds.
Press unlock button once to confirm programming.
Vehicle unlocks. Programming mode deactivated.
Switch ignition OFF. Remove key.
To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key:
Within 5 seconds press unlock button at 1 second intervals, as follows:
Twice for memory position 2 (second key).
Three times for memory position 3 (third key).
Four times for memory position 4 (fourth key).
Indicators flash once every time unlock button is pressed, to indicate signal received.
Wait 5 seconds.
NOTE: Ignition MUST be switched OFF between each key programming procedure.
Üldjuhul minul pole patareid vahetades auto pulti ära küll unustanud ;)
TK90
postitati 15.09.15 19:52 Tsiteeri
Proovin patarei siis ära vahetada, näis.
Igaks juhuks küsin, et kui ma tahaks lisaks ka puldi kesta vahetada (vana pult on üsna kulunud), kas piisab sellest, et tõstan selle elektroonilise sisu lihtsalt uude kesta üle?
rv30
Registreerunud 05.09.09
Auto: Audi TT 8N
postitati 16.09.15 15:38 Tsiteeri
Immo kiip tuleb ka uude kesta ümber tõsta. Selle kättesaamine vanast kestast ei pruugi lihtne olla.
TK90
postitati 16.09.15 16:43 Tsiteeri
Sain ära vahetatud ilusti. Alguses, pärast vahetamist, oli tumm korra aga tegin selle rituaali läbi nende õpetuste järgi ja hakkas tööle. Ei saanudki aru kas tänu õpetusele või hakkas ise kuidagi.
Tänud igatahes!
etsihel
Registreerunud 26.01.14
postitati 16.09.15 17:43 Tsiteeri
Tegelt piisab kui sa lihtsalt keerad korra võtmest lahti/kinni ja tunneb uuesti ära :)
[PHP: 15.6% - SQL: 84.4%]
