Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Kas sidur libiseb?
Registreerunud 18.07.15
Auto: a6 c4 1.9tdi
postitati 02.09.15 10:44
Kas sidur libiseb?
Tere
Ehk keegi siit oskab öelda milles probleem. Märkasin hiljuti, et auto hakkab veerema väikse kallaku peal kui käik sees(mootor väljas). Kahtlustasin,
et sidur libiseb aga sõiduajal ei ole mingit sidurilibisemist tunda. Auto läriseb kah madalamatel pööretel kuskil 1300-1500. Eriti on seda lärinat
kuulda tagurdamisel.
Oskan keegi öelda kas asi siduris või milleski muus.
Autoks on audi a6 c4 1.9 tdi
Ettetänades!
postitati 02.09.15 11:11
No kui sõidu ajal tdi sidur ei libise, siis ei libise ka kallaku peal.
Sõidu ajal on rakendatavad jõud ju kordi suuremad.
Kui vajub tagasi, siis on ikka mootor ise juba hõre ja sisiseb kusagilt tasapisi läbi.
Aga tee genekarihmale valge markeriga märk peale, siis on selge.
Auto: 6x4x4
postitati 02.09.15 11:38
Harju seisupidurit kasutama, on kõigile tervislikum. Seda juttu, et ei tööta pole mõtet siin teemas arutada.
postitati 02.09.15 17:05
Pane sisse esimene käik, mitte viies või kuues, siis ei libise ka midagi kuskile.
Ning üldiselt kui asi on kallaku peal võiks alati käsipiduri peale tõmmata.
sir-mac
Registreerunud 26.06.03
Auto: S6 4,2 Avant
postitati 02.09.15 18:07
Kässar võiks ikka kindlasti korras olla, aga kui ei looda selle peale eriti, kasuta seismise ajal R-käiku (mitte ralli- vaid tagurpidi käiku).
[PHP: 24.8% - SQL: 75.2%]
