Pealkiri: Audi A6 C5 kapott kinni (Vastuseid: 1 | Vaatamisi: 1427)
Undercover
Registreerunud 08.07.14
postitati 29.07.15 18:18 Tsiteeri
Tervist, mure siis selline, et sai kapott ilusti kinni lastud ja enam salongist lahti ei tule. Ilmselgelt tross järelt ära, kuna esiots oli ennem täiesti molekulideks. Kuidas saaks kerge vaevaga lahti? Põhja alt minu meelest ligipääsu väga ei olnud. :mad:
Tänud juba ette ära,
Undercover
raimo21
Registreerunud 21.08.09
Auto: A6
postitati 30.07.15 05:46 Tsiteeri
Kui inglise keelest aru saad, siis siit leiad ehk abi.
Get the front of the car up on ramps or jack stands. I used a big f-ing screwdriver / pry-bar (24") and went from underneath straight up to the release lever catch that the (hood release) wire ball attaches to. You will need to move a clip (with the prybar) that is obstructing your way to the lever. It also helps to have a friend with a flash light. Look at a friends A4 hood release mechanism to see what I am talking about regarding the clip and the path near the radiator the pry bar needs to go.
And remember you are upside down when moving the lever to release the hood. It goes toward the drivers side to release.
[PHP: 7.6% - SQL: 92.4%]
