Pealkiri: Parrot (Vastuseid: 1 | Vaatamisi: 947)
allu38
Registreerunud 06.01.15
postitati 15.07.15 13:52 Tsiteeri
Parrot
Audis selline seade nagu parrot 5.22 Kui telefoniga ühendada siis ütleb memory full.Mida teha......
Gunnark
Registreerunud 27.10.09
postitati 15.07.15 14:27 Tsiteeri
Algselt postitas: allu38
Võid proovida:
1.Press and hold the answer and end button on the parrot Bluetooth to wipe memory. Then try re-pairing using 1234 and password
2.
Firstly clear all of the old phones out of the CK3100. Settings>paired devices> a list of all paired devices will be displayed, select each one and delete
To check if you have sufficient memory go to settings>information – memory free. With no paired devices you should be looking at approximately 1040kb.
If the above is correct, can you check that the CK3100 displays a ‘Goodbye’ message on the screen when you turn the ignition off?
If this is not displayed the RED and ORANGE wires to the kit need to swapped at the fuse holders. The RED cable needs to be connected to a constant 12 volt supply and the ORANGE wire needs to be connected to the switched 12 volt supply (Ignition ON/OFF). Before swapping leave both the wires disconnected for 5 minutes.
If ‘Goodbye’ has not been displayed the kit has never been allowed to switch on or off correctly and over time this will cause a fake ‘Memory full’ message to develop with time. As soon as the unit is reset and the wiring is corrected as detailed above this will resolve the problem.
3.Kui tolku pole vajad softi uuendust 5.25ks või üles kui on, olenevalt telefonist jne...
For further information please contact the UK technical support team at: technical.uk@parrot.com or by calling +44(0)0844 472 2360
Parrot Advisor UK 3
Parrot UK & Ireland
E mail: http://www.parrot.com/uk/support/hotline/
[PHP: 21.7% - SQL: 78.3%]
