Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 1.8T AEB jahutusvedeliku kadu
Pealkiri: 1.8T AEB jahutusvedeliku kadu (Vastuseid: 0 | Vaatamisi: 745)
Mattias
Registreerunud 06.12.14
Auto: A6 C4 2.8Q
postitati 14.06.15 12:04 Tsiteeri
Palun kogenenumate abi seoses kummalise jahutusvedeliku kaoga 1.8 turbokal.
Nähtavat lekkekohta ei ole suutnud tuvastada. Ära olen vahetanud salongipoolel üleval asuva kolmiku korgi, mis enne lekkis. Sealtkandist on asi siiani kuiv. Kadu on umbes kuu aja ja ca 500-600km peale liiter.
Tagant valget suitsu ei tähelda, mootor saab töösoojaks mõistliku kiirusega.
Hetkel on auto 2 nädalat seisnud ja vahetult enne seda sai tase õigele kõrgusele pandud. Selle ajaga pole tase muutunud ja auto all loiku pole.
Kas turbo ?
Või lekib mõni tihend nii osavalt ?
Salongiradikas lekib pigem kaassõitja poole ?
Olen kuulnud ka "tüüpveast" et võib ka 1. silindrisse lekkida disainivea tõttu. Kui tõenäoline see 350tkm sõitnud mootoril on?
[PHP: 19.3% - SQL: 80.7%]
