Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi 80 b4 2.0 66kw 92a (sooviks oma autokohta teada)
Pealkiri: audi 80 b4 2.0 66kw 92a (sooviks oma autokohta teada) (Vastuseid: 2 | Vaatamisi: 1146)
ILAUDI
Registreerunud 28.04.15
postitati 29.05.15 14:07 Tsiteeri
keegi oskab ehk aidata?
mure järgmine audi 80 b4 2.0 66kw 92a Kas mootor keti või rihmaga? Kuna peaks rihma/ketti vahetama?
sviljar
Registreerunud 25.09.05
Auto: VW Passat B6
postitati 29.05.15 14:47 Tsiteeri
Tere.
Kõige lihtsam võta kate maha ja vaata. Minul sama mootoriga audi ja ikka rihmaga. Veel pole näinud ühtegi 2,0 66kw ketiga. Vahetama peaks kohe, kui sa ei tea kuna viimati vahetati. Rihmad ja rullikud ja veepump korraga vaheta siis kõik ok.
arakas2424
Registreerunud 13.10.08
postitati 30.05.15 19:21 Tsiteeri
Jah saan su murest aru. Mul täpselt sama moto ja aasta arvuga auto.See ikka rihmaga asi.Aga mina tegin rihma vahetuse hoopis teistmoodi.Tegin kapoti lahti vaatasin raisk 2,0 66 kw. viskasin selle mootori sealt nahuii ja peale läks 2,1 turbokas. ARK+ümmber ehitus luba ja 66 kw asemel ikka 4 korda rohkem.:D Soovitan sul pädevasse rem kohta.Kuna sa juba puusalt heitsid küsimuse kas ketiga moto või rihmaga.Siis pigem pöördu asja armastajate oole saab moto uue rihma ja sinul kaob varjant,et asendate veepumba pulpulaatoriga. kui kysimusi on ma võin aidata.
[PHP: 29.8% - SQL: 70.2%]
