Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 3.0 162 Pöörete probleem piduradamisel
Pealkiri: A4 3.0 162 Pöörete probleem piduradamisel (Vastuseid: 4 | Vaatamisi: 939)
zander91
postitusõiguseta
Auto: audi a4 b7 3.0Q
postitati 15.05.15 17:52 Tsiteeri
Nimelt mure vahest kõigutab pöördeid 50 rmp vahest 100 mitte rohkem,ning teeb seda ainult hoogumaha pidurdades ehk siis täieliku seisama jäämis hetkel.Sai diagnostika tehtud oli pidurivaakumpumba viga sees aga see on algusest saati sees olnd, ja mingeid kõrvalekaldeid pole varem olnd seoses sellle veaga.Sai ka vaakumit kontrollitud,et kas hoiab ja hoiab ilusti, lisaks sai ka kõik kahtlased vaakum voolikud vahetatud, puhastatud õhukululugeija.
Mootori tööd sai ka jälgitud ja graafiku järgi oli kõik korras.
Mida kahtlustada või kust ikkagi seda viga otsima hakata ?
3.0 162kw multitronic
zander91
postitusõiguseta
postitati 15.05.15 18:54 Tsiteeri
Lisan ka,et gaasiklapp puhastatud paar kuud tagasi.
Kasutaja on foorumis
postitati 15.05.15 21:30 Tsiteeri
Volvol oli sarnane teema. Peale gaasiklapi puhastamist (info autos, ei tea palju tegelikult näpiti) oli korraks hea ja õige pea hakkas uuesti jamama. Foori alla tühikäigul veeredes pöörded natuke kõikusid. Väidetav ravi oleks olnud tutikas detail.
zander91
postitusõiguseta
postitati 16.05.15 04:54 Tsiteeri
Algselt postitas: mkb
Endalgi oli s60 sellel oli hea lihtne gaasiklappi puhastada, audil vähe keerulisem ligi pääseda.aga lasen selle ka uuesti ära puhastada ja paika seadistada ikkagi.
zander91
postitusõiguseta
postitati 17.05.15 15:29 Tsiteeri
Täna sai klapp ilusti maha võetud ja korralikult ära puhastatud, varem oli kehvasti puhastatud.Hetkel pole veel pöörded kõikund aga eks näha ole lähipäevil ka teeb või ei .
[PHP: 28.9% - SQL: 71.1%]
