Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 1.9 TDi AJM 2000 [ei käivitu][KORRAS]
Pealkiri: Audi A4 1.9 TDi AJM 2000 [ei käivitu][KORRAS] (Vastuseid: 2 | Vaatamisi: 793)
MaarjoM
Registreerunud 26.12.14
Auto: audi 100 2.3 E C3
postitati 06.05.15 17:44 Tsiteeri
Tere, mure siis selline, et läksin ükspäev poodi, poes käidud, hakkasin käivitama ja tegi hirmsat traktori häält. Mootor nagu ei töötanud korralikult ja oli suht jõuetu, niimodi veeresin oma poolteist kilomeetrit, kuni mootor välja suri. Lasin ennast koju vedada ja nüüd seisab, starter ajab mootorit ilusti ringi ja süüdet andes kirjad ees, et kõik OK, aga käima ei lähe.
Mõtlesin, et vb kütusefilter umbes siis, aga ei taha kohe juppe vahetama hakata, tahaks kindel olla. Kas saab kuidagi testida, kas filter umbes? Seal nii palju voolikuid filtri küljes, et ei tea mis kuhu läheb.
TarmoValk
Registreerunud 27.06.14
Auto: Audi A6 3.0TDIQ
postitati 06.05.15 18:10 Tsiteeri
Kui küttefiltrit ei raatsi ka vahetada, siis las parem seisab.
Oli, on ja jääb - Audi
MaarjoM
postitati 07.05.15 09:32 Tsiteeri
Sai vähe targemate meestega räägitud ja oligi kütusefilter. Masinat on koguaeg hästi hooldatud ja varem pole selliseid asju ette tulnud. Ei tea mis "kala" seal filtris oli, aga nüüd korras. :D
[PHP: 30.2% - SQL: 69.8%]
