Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi c5 4.2 külmalt sõites mootori pöörded kõrged
Pealkiri: Audi c5 4.2 külmalt sõites mootori pöörded kõrged (Vastuseid: 5 | Vaatamisi: 1209)
Heikiiii
Registreerunud 16.04.13
Auto: C6 Allroad 2.7Tdi 2006
postitati 06.05.15 15:00 Tsiteeri
Tere, uuriksin, kas see on normaalne, et kui külmalt minna sõitma siis on mootoripöörded kõrgemad aga kui juba mingi 5min sõitnud siis langevad juba normi piiresse, muidu nagu probleemi pole, mootor ja kast toimetavad hästi, aga just selline asi.
Audi c5 4.2 2000a
waixu
Registreerunud 15.12.07
Auto: RS6 c5 2003
postitati 06.05.15 15:04 Tsiteeri
Mul teeb RS sama. Külma mootoriga vaikselt sõites vahetab esimeselt teisele alles 2000+ pöörde pealt. Kui ma ei eksi siis muidu teeb seda 1500 rpm pealt.
Volts123
Registreerunud 01.03.14
Auto: S6 c5
postitati 06.05.15 18:16 Tsiteeri
Hea ja hoolas peremees ei lähe külma mootoriga sõitma.:D
Fugitive
Registreerunud 12.02.06
postitati 06.05.15 18:47 Tsiteeri
Algselt postitas: Volts123
Eksid. Rahulikult sõites soojeneb mootor kiiremini. Kohapeal tiksudes peseb liigne kütus (segu on rikas ja kogu kütus ei põle korralikult ära) silindri seintelt õli maha ja see on mootorile kahjulikum.
Auto: 6x4x4
postitati 07.05.15 06:01 Tsiteeri
Käi korralikult kogu vaakumvoolikute jada ja vaakumvoolikutega kokkupuutuvad klapid üle. Endal avastasin ühe mõrase vooliku ja käitus sedasi, et hoidis külmalt pöördeid mingi aeg üleval ehk siis tavapärase ~2min ja ~1000-1100rpm asemel ~3-4min 1200-1300rpm (käikude vahetus ei puutu asjasse, see on normaalne). Ütleme siis nii, et vaikselt liikudes oli see ikkagi tuntavalt vastik kohapeal seista ja piduripedaaliga autot kinni hoida, mis vägisi edasi tahtis vedada. Ja tegelikult võib üldse "külmast peast" defineerida väga erinevalt just välistemperatuuri mõttes. -20C, 0C ja +20C on "külmast peast" täielikult erinevad asjad. Täistöösoojalt jäid pöörded vaevutajutavalt kõikuma algselt ja peale selle imeväikese lekke leidmist sain sellest +-20rpm pöörete kõikumisest kah lahti, mida ma tegelikult ei osanud üldse nagu kahtlustadagi millestki.
Teine väga suur tõenäosus sellisele käitumisele on kahjuks kütusepumba vaikne väsimine ja suremiseeelne seisund, kus pole enam korralikku survet ega ka tootlikkust. Ka pump kahjuks töötades kergelt soojeneb ja mingi aja möödudes hakkab kahjuks normaalselt käituma, aga käima pannes jääb survest lihtsalt piiiiiisut puudu ja see pihustitest "k*semine" põhjustab samuti tavapärasest kõrgemaid pöördeid selle tüübi mootoritel kui küttesegu on selline "veider" ja ebastabiilne.
PS! Mis Fugitive jutule veel lisaks, külmaga ongi mõistlik suhteliselt kiiresti vaikselt kulgema hakata, et ka teised sõlmed pisutki soojeneksid. See, et mootor on nüüd soe ja anname tuld mõjub tegelikult näiteks tiptronic kastile üsnagi laastavalt. Manualkasti puhul pole see ehk väga dramaatiline, kuigi ka seal oleks vaikne liikumine koos mootori soojenemisega üsnagi teretulnud ;). Mina kasutasin automaatkastidega näiteks mingeid väiksemaid kõrvaltee lõike peale külmkäivitusi, kus siis liiklusele jalgu ei jäänud enne kui põhimagistraalidele suundusin (seda pigem siis rohkem miinuskraadides välistemperatuuride juures).
Volts123
Auto: S6 c5
postitati 07.05.15 14:59 Tsiteeri
Algselt postitas: Fugitive
Kui nii siis tõesti vabandan...mina ka jälle targem.;)
[PHP: 25.4% - SQL: 74.6%]
