Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleem võtmega
Pealkiri: Probleem võtmega (Vastuseid: 2 | Vaatamisi: 860)
ehanurm
Registreerunud 22.10.10
Auto: Coupe 2.0 85kw '92 & E39
postitati 10.04.15 09:46 Tsiteeri
Probleem võtmega
Probleem Audi võtmega, täpsemalt kesklukuga. Uurisin internetist, et sellel võtmel peaks olema IR kesklukustus. Vahetasin võtmel patareid ära, aga ei funka ikkagi mitte midagi. Kas see tuluke (IR saatja) peaks vajutates nähtavalt mingit sähvatust või midagi tegema?
Autoks Audi A8 1996. Võti on ühe nupuga.
Võti ise selline :
http://www.upload.ee/image/4627974/IMAG0338.jpg
Kaar3l
Registreerunud 25.05.08
Auto: A6 C4 2.5TDI Quattro
postitati 10.04.15 09:50 Tsiteeri
IR valgust inimsilm ei näe. Kontrollida saad IR-i töötamist näiteks läbi telefoni/fotoka kaamera.
http://www.wikihow.com/See-Infared-Light
Sellel võtmel oli mingi paaritamise teema ka, et mõnel kippus unustama auto ära vms. Ise ma proovisin ka, aga normaalselt tööle ei saanud asja. :(
ehanurm
postitati 10.04.15 10:35 Tsiteeri
Algselt postitas: Kaar3l
Tänud vastuse eest, testisin võtit, nagu õpetuses kirjas, aga mingit sähvatust ei näinud, tundub et kas see IR saatja pirn läbi või midagi muud katki seal sees.
Eks proovin kõigepealt puldi saatja korda saada.
EDIT: Tänud Kaar3l, selle testimisega sain tööle puldi, kakkusin lahti puldi ja patareid ei andnud korralikult kiibile ühendust, kesklukk toimib puldist ilusti nüüd ;)
[PHP: 52.4% - SQL: 47.6%]
